I bought a Worth lift......
Defender Chassis
Williamstown, WV
It is a 10k lb two post unit. I also opted for an extra foot of width and an extra foot of height since there would be times when my 3500 series truck would be maintained on it. Most of the time the lift will be used doing fabrication work on race cars. I chose Worth mainly because they manufacture their lifts in the USA and their price was in my budget. I also considered Nussbaum and Mohawk. My research led me to several issues that others had with Worth and my experiences have not been all that different. I go over the details and start the unpacking process in the video link below. I will do follow-up videos on the installation and also do a final review that I will post in this thread.
Worth Lift Project - Part 1 Ordering and waiting
ybnormal70
Conway, SC
I've been about to pull the trigger on a Worth lift and I agree, info is very hard to come by it seems.
Subscribed!
Kevin
benz_dr
nw arkansas
I've had mine for four years. Love it, no problems. Very well built. If they had a better marketing program, they would blow away Bendpac imho
ybnormal70
Conway, SC
I placed my order with Worth today for the 12000EWT. I'll do an update as my lift purchase process continues.
Kevin
ybnormal70
Conway, SC
If you can answer, are the issues shipping related, build quality or what? A PM would be fine if you don't want to disclose just yet.
Thanks,
Kevin
D
Defender Chassis
Williamstown, WV
This project did not proceed as I desired or anticipated. The lift is currently up and is functional. The video will come at a later date. I thought that I would give a quick update though to let you all know what happened.
During the install I got the first column set and plumb then noticed that the upper column had a very noticeable lean. The upper column is inverted and slid inside the lower column during shipping. I do not have pictures but I do have video of how severe the lean was. The upper column is shorter than four feet and in that distance is was out of plumb by an inch. The upper column is just a plate with an I-beam welded to it. Some inspection work pointed toward the assembly being welded crooked. The other upper column suffered from the same deficiency. It was at this time that I thought it would be prudent to call Worth and get some direction. I got Steve Prater on the phone and described the condition and he indicated that this was not an unusual condition. He seemed to blame it on a couple things like an old jig used for welding and the way the shipper lifts the package when in transport. The fix was simple though. He instructed me to shim the base of the upper column as needed to get it into a plumb condition. This is when the conversation took a different direction. I then asked him to send me an email detailing the discussion we just had as an addendum to the instructions. He then got very defensive and acted like I should just take his word for it. This position took me by surprise since the instruction say on the first page that unapproved materials would void the manufactures warranty. It was evident that Steve was not going to back up his verbal direction on paper so I decided to take another direction. In the past when in this position I typically send an email detailing the discussion and asking for any correction. If no reply is made you have proof that the other party conceded to some extent. Although this is not as good as getting formal written direction it is the best you can sometimes do with an uncooperative vendor.
The balance of the install went relatively smooth but I have several issues that I will discuss in the video. Two of the issues were of enough concern that I decided to get direction before I put the lift into service. The first one had to do with the carriages. The carriages are made of a piece of square tubing. The cables either attach to or pass though three of the four corners of this square tube. Although the instructions indicate that there should be a plate on top of the carriage with four holes, the lift I received did not have a plate but just a lug welded in three corners. The odd thing is that one of the lugs is in a corner that the cable does not attach or pass. This lead me to think that one lug was welded in the wrong position. This was the case for both carriages. In addition, the lugs are welded on a bit crooked. So crooked that you can see with your naked eye that the cable end stud does not follow the natural path of the cable. The second issue has to do with the hose connection at the pump. The supplied fittings and hoses did not facilitate installation in the natural/vertical direction because the hoses clashed with the oil tank/motor. I initially thought they may have changed pump vendor and maybe did not check to make sure the new assembly worked with the old hose routing. I was able to get the hoses attached by turning the tee at approximately 45 degrees but the hoses are really too short for this. I went ahead and used them in this position to bleed the air from the system and cycle the carriages up and down. I also tensioned the cable and timed them properly per the directions from Worth. This was actually easier than I anticipated. At this time I decided to go ahead and send Steve Prater an email to 1) Confirm that I properly followed his direction on shimming the upper columns, 2) Let him know about the issue with the hoses/fittings, and 3) Get his input on the issues outlined above with the carriages. Following is the text from the email. The pictures are attached and labeled just as I reference them:
Steve,
I want to touch base with you on three issues with regard to my new Worth 10000CF lift. I have attached pictures detailing my concerns and will reference them by number. If you need better pictures do not hesitate to request them.
The first issue is the same one that we discussed on the phone last Thursday and has to do with the upper columns not being plumb even though the lower column was. I shimmed them as you instructed me and did not need as much shimming as I anticipated. I ended up placing one washer under both of the bolts on the side of the column that faces in. The washers are approximately 1/8" thick and you can see the details in pictures numbered one and two. Please confirm that I followed your instructions adequately.
The second issue has to do with the attachment of the hydraulic lines to the pump. The supplied tee does not protrude past the motor and tank far enough to allow proper attachment of the hoses. This can be seen in the attached pictures three and four. To make the connection you see in the pictures I had to rotate the tee which meant that the hoses had to take an indirect route in which they are not really long enough for. Please advise a solution for this problem.
The third issue has to do with the carriages. Although the instructions indicate that there should be four holes on top of each carriage for the cable to connect and/or pass through, there are actually only three. Three lugs are all that are needed to facilitate the cable routing but there is actually one located in the corner where it is not required and the corner where the cable just passes through there is none. Please reference pictures five and six for details. This is the case for both carriages on my lift. In addition, the lugs where the cables terminate are welded on crooked enough to be noticeable with the naked eye. This means the cable end is slightly crooked and not pointed directly along the cables natural path. Please reference pictures seven, eight and nine for more detail. This is also the case on both carriages.
My lift is currently completely assembled and has been cycled without a load. I am going to wait for your response to the three issues above before I proceed to cycling the lift under load to complete the bleeding of the air from the hydraulic system and put it into service.
Regards,
Scott Matheny
I sent this email late on Sunday April 9th. After no response I called him on Tuesday, April 11th at 4:04 EST. I was told he was out and I asked them to let him know I was calling him with respect to my email. He called me back at 5:43 pm EST the same day. I will not get into the tone of the conversation but will say it was cordial and professional. In short his response was as follows:
1) The shimming looks good and is just as he described.
2) The hoses and fittings are what they have been using for a long time and I installed them just as needed and there is no problem with the way they are installed.
3) The carriages are built correctly. The extra lug in the unused position is for models that have cables that run along the floor. The angle to the lugs is intentional to prevent interference between the cables and the cylinder.
He also indicated that he did not see anything in the pictures that would preclude me from operating the lift with weight on it.
I have since operated the lift under load. I had a small car on it that weighed under 3k lbs.
My take on the three issues are as follows:
1) I wish the upper columns were better fabricated and did not lean. It is evident that Worth has no intent of doing anything about this and I am not sure that the shimming is an unreasonable fix. I do think that if shimming is the factory approved fix then they should issue an addendum to the instructions covering the modification.
2) The hoses/fittings are a cluster. In no way is this a reasonable installation. I will personally fix this issue with a different fitting combination or I may even run hard lines and shorten the hoses. It is not worth my time and/or frustration to argue this with Worth. The cost will be minimal and will take less time if I just do it myself.
3) I buy the explanation about the extra lug being for a different model. I am not convinced that the lugs being welded on crooked was intentional. Worth is on record knowing that the condition exists so that is good enough for me to feel comfortable using the equipment.
Additional Note: I do not want this post to come off as insinuating my Worth lift is junk. The construction is quite heavy and it functions well. I am not an expert on what is available so take this statement with that in mind, this lift is likely better than at least 75% of everything else available. please stay tuned for the video with all of the other details.
Regards,
Scott
danbuff
Western NY
For the hydraulic hose, I suggest a straight female to male o-ring adapter which will act as an extension to get you past the reservoir. Your local hydraulics shop should be able to provide one.
For the 'crooked' cable, if you give me a out of plumb degree, I could machine a tapered 'washer/adapter' for you to fit under the crooked tab, to bring the cable back plumb.. if you know what I mean. Or if you have a machinist buddy he could do.
Dan
D
Defender Chassis
Williamstown, WV
Dan
That is exactly what I was thinking about on the hoses as well. I really do not like to have hoses that long and am actually considering running hard line. Not sure yet but I will post details when I get there.
I appreciate the offer on the wedges. I have the capability to do the same in my shop but was actually considering spherical washers. Steve Prater from Worth thinks having the end of that cable kinked sideways is acceptable. Do you not agree? Would you fix it or run it?
Link to spherical washers
danbuff
Western NY
I would correct it.. Shouldn't be a big deal to fabricate something.. Good excuse to use the tools. :) I don't think it would be an issue to leave it as is But may as well correct it.
greggo
Hi Scott: Thank You for taking the time to post your experience with your Worth lifts.I'm in the market for a 2 post lift either clear floor or base plate and Worth was on my top 3 list. The problems you have are unacceptable for a new lift. I spoke to Steve Prater a couple of weeks ago apparently he is the owner/president of the company. From what I'm seeing he is NOT taking responsibility for the fabrication screw ups.
We all work hard and when you shell out a good chunk of change on an expensive new lift you want it to be it new condition. You ordered new so YOU would'nt have to screw around with it. If you bought used you would expect for some fiddling around but NOT on a NEW lift.
I definitely will NOT be buying a WORTH lift. If they teat you this shoddy when the lift is new makes me wonder whats in store for the future with them.
I totally understand the made in USA thing but Worth is a small company with a small amount of employees.
How many employees does rotary,challenger,and forward employ in this country even if there lifts are made in China.
Please don"t take my post the wrong way, I was about to possibly pull the trigger on one of there lifts . and I deeply appreciate your post on it.
Thank You Again!
Patchzx7r
Denver, CO
This post makes me very nervous, I'll be receiving and installing mine in the coming days, I can already here the attitude from Steve given the issues I had with my order.
Guys like him need to not talk to customers and I wish you would have posted part 2 of the video.
Diesel Dan
TN
I've bought 2 lifts new from worth over the last few years. One 9K floor plate and one 10K clear floor, extra wide. From what I recall they shipped in the 12 week time frame, long but what I was told. Both needed new HPUs because shippers damaged them with fork trucks and Worth shipped replacement ones right away with return shipper labels.
IIRC the cable lugs leaning helps when the lift is at full height and the carriage is right up by the pulleys.
Spherical washers "look" like they would be a good upgrade. Some EP lube on the mating surfaces would allow them to self align under load.
For the $2-5 for a different hydraulic fitting would seem like a easy factory change to clean things up.
Don't recall having the top supports lean like yours.
Do wish they'd offer different arm styles, would really like one set to be 3 stage. Plus bring back the low profile arms for the lighter lifts, especially in todays world of low rides. It was tight getting a 300C onto my 10K lift.
Worth is still the top of my list for a 3rd lift when the house is done.
xctreker
In a Barn
Patch,
How'd it go for you? I just got off the phone with Steve and I still waiting on my Rotary quote.
Mr_fixit
Rustylvania
I ordered and paid for a worth lift on 2/22/18. They have yet to ship. I expected 12 weeks, from what everyone said, so up front , written on the invoice I gave them more time, documenting I required it by 6/1/18. They didn't deliver. I emailed 2 weeks later after they missed the 6/1 date and Steve said it would ship 7/1, saying something about a piece of equipment that they ( or a contractor?) makes the rolling jacks on was broke. It's past 7/1 and I haven't heard anything from them.
I'm not happy. More to come.
xctreker
In a Barn
Arg, I just pulled the trigger on the Worth 10000ACF. He quoted me 8 weeks... Which model did you order?
Diesel Dan
TN
It has to be aggravating to say the least.
I can understand large spot orders or equipment break downs causing delays. However these lifts have been running a lead time of 12-20 weeks for what, 5-10 years? At least that I'm aware of.
At what point do you consider a upward sales trend as the norm?
The Challenger CL10V3-2 is sounding more appealing.
I will still do what I can to buy a USA made lift.
ybnormal70
Conway, SC
Yeah cause this seems to be the norm with them. The excuses I was given:
1: We had a municipality place a large order just before I did.
2. Bad weather/flooding in Texas.
There was another one I believe but I'd have to search my emails for it as I don't remember right this second. I'm thinking it was something about paint drying.
Kevin
cc_rider
Austin Texas
I am having the same problem as Mr_fixit. I ordered a lift on April 2 2018. I paid $3600 up front. It's July 12th. Now I can't get them to return an email or phone call. I hate to say it, but it looks like now they are just scamming people.
I am considering legal action.
cc_rider
Austin Texas
All,
I just filed a complaint with the BBB. They have an A+ rating based on one review, no complaints (until now).
If you file a complaint with the BBB, it might get their attention.
c.
Diesel Dan
TN
If you're concerned about any nefarious actions on their behalf I'd suggest a road trip to their shop in Mansfield. Should be about a 3 hr trip for you?
Complaint to the BBB is a legit.
My first lift from them was +/- 10 yrs ago and about 12 week wait. You'd think after all this time they would be getting better at delivery, not worse.
CC_Rider, what are the specs on the lift you ordered?
jscoggin
Midlothian,TX
This thread is unfortunate. My shop is just about to break ground and I was about to contact Worth to place an order. I live about ten minutes from them and was excited to be so close in the event of needing service, repair or parts. After seeing the complaints of shoddy finish quality, as well as an apparent complete lack of customer service, it looks like I will be taking my lift money somewhere else, what a shame.
Diesel Dan
TN
Swing by an take a picture of the facility if you can.
Curious to see how it looks now.
mr.dude
I purchased a lift from worth the first week of may. I called last week and was told it will be done by 7-20,
Diesel Dan
TN
Unless I'm missing something, you are at 11 weeks. 7/20 would be 12 weeks, which is what others have said is the lead time.
He is definitely past the 12 week window.
For those that have ordered give off you lift models and specs, ie extra tall, wide etc.
jscoggin
Midlothian,TX
I've driven by the facility twice in the last week. I didn't go in and didn't take pictures but have to say, the facility didn't give me warm fuzzies. I'm not sure what I expected it to look like but it certainly didn't look like an operation that was thriving.
Then again, I appreciate companies that keep costs low by not having unnecessary overhead so appearances aren't always everything. However, a lack of customer service, failure to deliver items in promised timelines and shoddy construction are. I'll reserve final judgment until a few of the members above actually get the items they paid for and are able to give a review of their lifts.
