josh7owens
- Joined
- Jul 27, 2016
- Messages
- 44
So about 6 months ago I built the first long bench. It's 26" wide and 9' long. I had intentions on building another one to make it into an L shape but just got around to finishing it 6 month later. I probably have 40 hours in building all of them once you include cuting, welding, designing, sanding, painting, etc.
The second bench of the series is the one with the inserted toolbox. Instead of wood shelves like I built the first one I decided to do expanded metal. In my opinion it looks better. The second bench ended up being 29" wide and 7' long.
The comes the fun one! SO initially I was planning on just making the second bench 10' long with a 3' bench table that I could work on stuff while sitting in a stool, that later evolved. I had this thought of why not just put it on wheels so it can roll around the garage? That then evolved into making it a welding table/ work bench. (more about that in a min) Initially I was going to make a small roller cart for my welder then changed my mind to making a floating shelve for the welder. The problem was where in the world would I put the Argon mix? So I came up with the idea of using scuba tank mounts welded on to mount the tank horizontally. Ofcourse I had to make a hook to hold all of the hoses also. The final touch was adding a removable vice mount on one side and then adding a 3' side out that's height adjustable on the other side. This portable work bench has a top that's is 29"x52".
The adjustable feet for these new benches will be in tomorrow and the plan is to replace the OSB top with a custom sized 3/8" thickness FabBlock from CertiFlat tables. Although it's $1000 and I haven't ordered it yet!
What do you think?!
What do you think?!
