I cant figure this out, please help
Gnfantic
Long Island, NY
Hey guys, I installed the plywood walls in my garage and now wiring up the outlets. I used #6ga 3 way wire for my 50 amp outlets (welders) and piggy backed the outlets around the garage so I can move my welding cart around if needed. Problem is all the 240 volt 50 amp outlets I see only have room for 1 wire per a terminal. How do I connect the other wire? I am attaching a pic of one of the outlets just in case I am not explaining it properly.
thanks guys!
G
Gnfantic
Long Island, NY
I would have to take down about 10 sheets of plywood and alot of screws. If have to do it, what do I install 6x6 box and use polaris connections?
thanks guys!
You will not find a nema outlet that is rated for more than one wire per lug.
Have to use blue wire nuts, split bolts or polaris connectors.
G
Gnfantic
Long Island, NY
Well, look what we have here. for shits and giggles I got 2 #6 wires to see if they fit and they do.. Is this dangerous?? UN-acceptable? I am only be using the welder for this line, no other equipment.
thanks guys
sparky 1971
Central Iowa
Get a 4 11/16" X 2 1/8" deep box. If it were me, I would get a 2 gang 1 1/4" raised mud ring and mount the box so the face of the ring is flush with the wall. The big box stores around me don't have the mud rings, that's a supply house item. I do the same thing with range receptacles, but use deep 4X4 boxes since there are no splices.
frankush
IL
Don't do that. Get a bigger box and pig tail the wires using split bolts. Even if two wires under a terminal was allowed, you would play hell getting everything stuffed into that handy box.
Good advice here. X2 on the 4-11/16 box and ring.
coljar
Belpre, Ohio
[/url][/IMG]
I'm doing basically the same as you, but using these on my #6 wire to jump to the other outlet.
yatg
Southern Oregon
Too late now, but you could have had a central junction box and did a home run from each receptacle box to it, then make all your connections in one place on a distribution block.
pattenp
Virginia - USA
Just a friendly FYI, if your state/locality has adopted the International Residential Code (IRC), which some states have, section E3702.5 does not allow for a multiple outlet circuit to be over 20A. I got surprised by this code here in Virginai when I applied for an electrical permit to wire my home garage/shop and I was showing a 50A multioutlet circuit. I ended up with one 50A outlet and use a long extension cord for my welder.
Edit: I believe Ohio has adopted the IRC. Appears New York state adopted the IRC, but New York City as an exception to the IRC uses the NEC for electrical.
Look here: https://up.codes/?s
