I need a floor
russ27
CEPA
I'm rehabbing a 12x16 shed in my back yard, post and beam construction. built in 1970. I will be adding a 8x16 bump out
rebuilding isn't an option..it would be much easier if i could. but set backs wont allow it and i don't have room anywhere else on my lot.
i really wanted to pour a floating slab in the existing part, then do a wood floor on the bump out. i'm concerned with the existing grade, the grade slopes from my neighbors yard towards the shed, that i will end up with water issues, i'm toying with the idea of putting a wood framed floor sitting on a 3/4" gravel base to avoid that.
thoughts or ideas?
end goal
audioworks04
Olathe KS
So is the question about the grade of your yard? If you are asking if you should put a gravel base down so that water can migrate its way through the shed then no. A wood floor is fine if you are fine with a wood floor, but concrete and "forever". I would say you need to regrade you yard some or add some curb that will re direct the water around the shed.
