I Need Ideas For This....
freudianfloyd
Nowhere
454ragtop
Carver, MA
Looks like it would be easy enough to add on to the legs with some angle iron to get it up to a usable height, for what I don't know. Might make a good portable welding bench if you fit a table top inside the frame work, then you could use the tee track for hold downs.
Jim
rsanter
visalia ca
If you have several table top type power tools you could easily put a top on it and make it such that all of those tools will mount to it using pins or clamps
Bob
WhoWhatNow
Collegeville, PA
That is made out of 80/20 or some equivalent. You can buy pieces of 80/20 for a reasonable price on eBay to get the height you want for a bench. The stuff is pretty expensive but very nice.
F
freudianfloyd
Nowhere
Jim
The reason I took it was to use as a weld table, but didnt realize how short it was.
F
freudianfloyd
Nowhere
I have access to random pieces of 80/20 at work, so it can be turned into anything really, it just looks like it would be perfect for something like it is, just not sure what. Worse case scenario it gets disassembled and saved for later.
F
freudianfloyd
Nowhere
Bob
Thats a good idea. I was also thinking of turning it into a jack, ramp, jack stand station but not sure if its worth it.
KamiCrit
North Of The 49th And West Of Everything.
The three rails in the middle, drop those to the bottom. Take a rail that is spanning the top and add it to the bottom side with no rail. The other spanning rail move it to the middle of the span.
Now the frame is rigid, and ready for crazy ideas.
TAMPAGT07
Palm Harbor, Fl
It looks very sturdy. I think I'd mount a bottom tool chest on it.. Or you could send it off to Haugy and he could mount his hot **** neighbor on it.... Just a thought..
jgorm
San Diego
I scored tons of 8020 from my work. I just disassembled everything for future use. Then you can build what you want.
HammerMechanic
NE OH
Being that it is 8020, you can easily use it for anything. If you have anything that needs a tub/tank that would be probably a nice height such as dunk tank, electrolysis tank, part washer, etc.
