Icon T7 scan tool
M635_Guy
NC
Try one of these in the correct size.
All you can really tell with a scan tool, and not all may be available:
1) Is a charging fault set? Codes may not even exist depending on the car.
2) What is current system voltage?
3) What is commanded/target/set point voltage? For instance a Kia may charge at 12.3v idling and be 100% as designed.
4) What is the commanded duty cycle/output/whatever? How hard is the PCM trying to command this alternator? Going 100% wide open with no charging? Does the PCM even know there's a problem? Is the PCM even who is in charge of the alternator?
Other than that you'll need to do a basic voltage drop/big test light test on the B+ cable and the block, and check inputs into the alternator on the electrical plug.
Yesterday I had a dead Rover, bad alternator. B+/B- good with big *** test lamp, good enough it should charge something. Single wire alternator, LIN bus communication, scope shows a pattern of "something" which look like good data packets. Replace alternator.
Then an Avalon, also bad alternator. Big *** test lamp confirms cables/block acceptable, 4 pin connector. 1 constant B+ feed, one is switched, both good. Another for the warning light, don't really care about that. The last is a PWM signal at key on engine off, pulls down to ground upon starting which I assume is full output. Replace alternator.
The problem learning a scan tool, is you/me/nobody knows what data is inherently in it, or how to find it. So you try to find the info you can and do with it what you can. I didn't know the LIN bus on the Rover was 0-12v, or ground was full output on the Toyota. But looking at charging commanded output, actual output, and duty cycle to the alternator made it more apparent how the system was designed. The voltage plunged after startup so I wasn't convinced to bother doing a voltage drop on the alternator cable, it was clear there was absolutely zero output. I always do that test engine off, so a charging alternator won't fool me the cable is bad.
Typically, typically, if the red battery light is on, you have some issue. If it isn't, the PCM is generally okay with the charging system function. But the toyota had no charging system light on at 11 volts at idle. So who knows.
The battery was a fairly new one (Jan of this year, nice Duralast Gold yadda yadda, but was junk. They swapped it immediately.
By my multimeter and the Autel it's running 13.5V even with a load (high-beam/AC/Radio), so it seems like it's regulating and charging...
...but possibly marginal? Everything seems to say 14V +/- is where you want to see it.
That's not the right tool to test a alternator, if you want to see charge cmd rate and actual output rate yes but, that's not a thing on a Mazda 3.
It seems like some of the newer scanners will give you the OE spec. The Launch scanners can have a BT unit hooked up to the battery for testing (this appears in the Icon line, but only the T10 poe6hb.gif).
2ndGearRubber
Pittsburgh
That's the question "seems to say 14v". What's that worth? A Kia can be happy at 12.3, less than a fully charged battery should test for resting voltage. That scrambled my brain the first time I saw it. The Rover yesterday was ~15. Toyota avalon was high 13s.
Your scan tool should provide the target charging voltage and actual voltage, somewhere, in the PCM live data if it's available. Some brands simply don't have a PID for it. A basic test could be, with the car running, voltage drop the B+ post of the alternator to the B+ post of the battery, and the alternator case/engine itself to battery B- post. If those are good, probably .25v or less is still acceptable, your alternator is likely doing as it's told. Ideally sub 0.1v, but IDK how rusty your area is.
richfinn
Leeds, Yorkshire, England
Does this Mazda have a battery monitor sensor on the negative battery cable?
The output voltage can appear low with these smart charge systems, try loading it up with headlamp main beams, heater blower and heated screens and they normally come up to a more traditional value around 14.00v after a minute or so
I always do this before I look at the control side/start volt dropping the main cable and grounds.
It's also worth disconnecting the alternator plug to see if the vehicle actually sets DTCs/or defaults to a higher charging voltage
M635_Guy
NC
Apologies - I didn't mean to hijack the Icon T7 thread with my incompetency. I'll wrap up below on the distraction with a couple comments there, but on the topical point what I was trying to say was that some of the more traditional tools are built around the structure of the OBDII platform and whatever the various OEM's use to stack their proprietary stuff on top of it. The interface for the scanners is inside out, instead of being more use-case and user driven. Trained/experienced techs probably see the structure I don't.
All that made my head ache. What I've gathered would have led me to believe that the electrical system was pretty much the electrical system, and the Kia and the Rover should be chewing up batteries. But somehow that's not the case. I'd **** as a tech.
Not rusty pretty much at all. Warm enough that we don't use salt and far enough from the shore that it doesn't get us either (but still an easy drive :))
I'd have to look, but it seemed like a pretty simple cable on that side, so I sorta doubt it.
I had the hi-beams, AC and radio going for a bit, and it still sat at 13.5V.
I'll go back with the Autel and see if I can find this stuff in the live data, but I don't think I saw it this afternoon. I might have missed it, but it seems like the kind of thing they'd put in an easier place - why not make some shortcuts to the most-common things???
2ndGearRubber
Pittsburgh
On topic- that's why snap on has an excellent interface. The Autel is more like the various factory tools, the snap on tries to organize in a more consistent way between brands. Launch software is a blend of these two ideas. Some stuff never makes sense. Like Chrysler has no misfire detection data. It's a "special function" called Which Cylinder Is Misfiring?. But who'd look in special functions for misfire data?
At a certain point all the modules need listed. For instance the TPMS may be built into the function of the body control module. On a snap on tool they'll usually have a TPMS function which just redirects you to the screen you need. But you can also just go to the BCM directly and find what you need. Autel/launch have the "services" menu but sometimes those tests don't work right in the services menu, but work fine when accessed from the modules functional test screen. Happened to me last week with electronic parking brake on a BMW.
Typically a circuit at max steady state load will move about half the fused value. So a typical 40amp fused blower would have ~20amps constant draw on high. Blower, rear defroster, high beams, all great ways to load up a charging system. If I've learned anything about rules of thumb, it's that they don't exist. It's a PITA because so much stuff falls under the umbrella of an exception, it's like there's more exceptions than followers of the rules.
BTW: You're not alone in "where's this goddamn data pid?!?!". Or service info stating "the module then used logic to perform the function". Great explanation of the circuit design, thanks.
M635_Guy
NC
Some kind of reverse-lookup mode by regular-language description would be great. The first vendor to have an AI-driven interface might actually kick some **** for a while...
:ROFLMAO: That does make me feel a little better. I can't afford (much less justify) a Snap On, so it seems like a Launch model might be a good idea.
I need to look and see if there's any gotcha between how Launch handles/prices updates vs. HF - seems like I read somewhere that said HF had good pricing on updates, but I'd want to know which updates...
(BTW folks - as a result of all this my Autel MX900 is for sale. Used thrice!)
[To close the chapter on the Mazda, Advance Auto's machine read the alternator at 13.7V and declared it just dandy.]
richfinn
One great feature on Launch software based scan tools is the search bar, if you are looking for a particular PID just type in something relatable like "battery, voltage or generator" and it will narrow things down to make selection a bit easier (once you get used to the whacky Chinglish translations).
A
AJHD
Unless I find a better option in the meantime, I still plan on picking up the T7.
I'd like to wait for a coupon or sale, but we'll see.
Again, as a DIY these days, I think it will do what I need it to when I happen to need it.
2ndGearRubber
Pittsburgh
Please post about it if you do, information is lacking.
Soundguy39
I'm in the market for a "budget" level bi-directional scan tool. I'm not wrenching in a shop these days, so I don't need a Snap On or something else with all the features of a high dollar unit, including Bluetooth (I don't need it and don't care for it).
I've had my eye on the Autel MX808, especially since Autel added a bunch of di-directional features. But HF has been putting out some scan tools under Icon, which I've heard are based on Launch. The T7 model looks like it might be a good alternative to the Autel 808. It's priced about the same, especially with a coupon or some form of other applicable discount. I'm not concerned about the "TrueFix" software either, I'm more concerned about the scan tool itself and its software.
I know these are new. I'm sure very few people have them. But I wanted to start a conversation and get some opinions.
However, I don't care about HF hate or why I should spend 3x more on something else also made in China. That's not the point of this thread, so take it elsewhere.
I have seen Eric O' with what I believe is the T10 model in a few of his most recent videos. That's beyond my needs and it's a higher-level more expensive model, but more importantly it seems to work, with the exception of learning where everything is and how everything works. Eric normally uses one of the more expensive Autel units in most of his videos and the software is obviously different.
I actually own an Icon T7 Diagnostic Analyzer. I have only had it for about a month, but I can tell you it does have great Bi-directional features and right out of the bow, it seems to be an effective tool. My concern as it uses Launch software, that after my initial year is up, I will lose functions and the abilities to continue to have them available. It already will not go some sites that it links to after the error code is displayed. I have a 2007 Volvo XC90, and I was able to scan, read codes, get module info, and clear them. It does not do a couple features that it claimed when I did their application test in the brochure.
The problem I have with it, is that it comes with no user manual whatsoever. After you get it online, and register it, the "how to use this thing" info is all online and you have to exit out of the diagnostic you are doing and go to the main menu to access it. Screen captures are stored somewhere that I have not discerned yet, and I can't seem to save data so I can recall it, export it, or print it. I have not been able to connect it to another device like my cell or tablet either, although it is worded like it should be no big deal. I'm recently retired mechanic of over 40 years professionally, ASE certified, Honda and Toyota certified, etc. Smog licensee too. If I am having a gard time with this, there must be a reason. I'm only 63 and am still computer proficient and still pretty darn sharp. I'm going to talk to the guys at Harbor Freight, and Icon and see what they say, or I may just be returning it for something more what I need that hopefully won't break the bank. I paid $349 for it and for the money, the things it does are easy and rewarding, but other things it claimed to do, and that I want it for,
A
AJHD
I ended up buying the Autel MX808 last year for $266 with tax/shipping.
It's done everything I asked it to. Autel had frequent updates adding features and models. But unfortunately I did not renew the software license when it expired awhile back.
