DugT
Yesterday I bought a new HF Icon 1/2" torque wrench and it is surprisingly accurate and consistent. According to its callibration report, the worst reading out of 9 measurement was only 0.73% off from perfect. Two of the measurements were perfect to 4 decimal places. Their spec says within +/-4.00% but on average of the nine measurements, the wrench is accurate within 0.34%. I am really impressed!
For many applications, consistancy is as important as being within spec. For example, if I was torguing head bolts or wheel lugs, ideally the torque would be identical on all of them. With this wrench, for the 150 ft lb setting, all three readings were within .04% of each other. That is The worst consistency was at 50 ft lbs. Those three readings were within 0.18% of the average of the three readings. One of the measurements was perfect at 50 ft lbs and both of the other measurements were 49.8 ft lbs. I think that is amazing and maybe unnecessarily accurate.
On a side note, to adjust the calibration of this wrench you remove the cover from the bottom, loosen the nut and adjust the spring tension with an allen wrench. This is the same as my old Matco wrench but I never found a socket that was thin enough to get to that nut. I had to grind down some long nose pliers. The point is, this Icon should be easy to recalibrate.
