ID this heavy duty hitch
RichWentFishing
I helped clear out a shed for my girlfriends dad today. He gave me this 2" hitch. It's really solid and all solid steel. Does anyone know who made it? It has a 2 5/16" ball on it. I put it on my truck and will mostly just use it as a tailgating deterrent but I wanna clean it up and paint it.
Also what are those two little pieces of metal for at the end?
R
RichWentFishing
Cool. Thanks for the quick reply. I'm gonna spray paint it and leave it in my truck for a while and use it as a step.
koditten
Midland, Michigan
Not really worth much without the bars. Most people would rather handle something that is much lighter if they don't need the weight distribution hitch.
manwithtools
Lebanon, TN
Let us know how many times you smash your shin on it before you pull it out.
Or when someone else smacks their shin on it. It bugs me to no end that folks leave these in the receiver hitch when they aren't going to tow anything for the next year and a half. Why have a receiver hitch? Just weld the stupid thing to the frame if you are not going to take it off.
I don't walk close to other folks vehicles; so not much chance I'm going to bang my shin on it, but I have seen people walk into them on occasion in the parking lot at work. Just seems like a courtesy to everyone to take the adapter out when not in use. I'm just crotchety about things like that the older I get.
ChevyEFI
Phoenix, AZ
Seems dumb to just install it without a real purpose or use
Tailgate deterent or step is not a good use. They make steps for that
He should install a step, requiring him to remove that and put a hitch on when needed, rather than use what he has that works. Got it. :confused:
bmxdad
Puyallup, WA
Chains go in the holes with a slot. Take it off, or someone will take it off for you ... just saying.
cre73
Central Illinois
I leave smaller hitches in all the time, large one for the camper I pull off as soon as I am done. I believe in Illinois they made it illegal to have one installed while not towing something. Haven't seen or heard of any tickets for it. As stated I leave my standard hitches in.
LB-1911
Northwestern Il.
:fingersx:
No need to perpetuate this 5 year old rumor.
Short Description: VEH CD-TRAILER HITCHES-REMOVAL
Amends the Illinois Vehicle Code. Provides that if any portion of a motor vehicle hitch containing a ball mount and hitch receiver extends more than 4 inches beyond the motor vehicle's rear bumper, then the ball mount must be removed from the hitch receiver when the motor vehicle is not being used for towing. Provides that if any portion of a motor vehicle hitch extends more than 4 inches beyond the rear bumper of the motor vehicle and the hitch is composed of a single assembly that cannot be easily removed from the vehicle, then the ball of the hitch must be covered with a red cover. Defines "ball mount", "hitch receiver", and "motor vehicle hitch".
Last Action
Date - - Chamber - - Action
1/11/2011 - - House - - Session Sine Die*
* without any future date being designated
:see:
http://www.ilga.gov/legislation/Bil...GAID=10&DocTypeID=HB&LegId=46447&SessionID=76
mudhog
south Bygod Texas
Yep that is a typical weight distribution hitch made to level your truck and trailer when you have a heavy load. That piece of flat bar with the small hole sticking out to the side is for a sway bar, that has a small ball that mounts in the hole for the sway bar attachment. I leave my hitch in all the time because I move my trailers around when I mow, and pull trailers about every weekend, they are parked in grass.
zkdiesel
chicagoland cornfields
Correct but poster doesn't wanna pull trailers....
Hghgrad
Detroit MI
I never hit my shins on mine...and I generally always have one in. I use mine to take the garbage cans down the long driveway. I also tow trailers on a weekly basis...
4 FN 27
Minnesnowta
Weight Distributing Hitch. I leave mine on all winter. Have since 1990. Been rear-ended twice with it. No damage to my truck. One car was totaled and the other was able to drive away. Been bumped a few times in the drive thru people trying to get close.
After a few shin bangs you learn to walk wide arcs around all pick-ups.
Mine looks like a little newer version of that on. Has the same type of release system for the bars but the sway bar mount is slightly different. Mine is a 1990 Reese.
I still use mine for the big trailer but with out the Bars on it. I know I shouldn't but I like the ability to adjust the ball height. I made shims to take up the slop in the slotted hole so it is not moving around.
