quickfarms
Call snap on, if you are the original purchaser they are covered under warrantyWhere do you get new slides? Coworker at work has an old one that has friction slides and some are busted.
I talked to snapon customer service last week and the slides are available, but the part numbers have changed from the originals, I will look in the morning and post the part numbersThese are now getting to the age where slides may or may not be available.
I’ve had decent luck getting slides for late 80’s boxes and newer, but it is hit or miss for the older stuff.
Asking your SO dealer is the best way to know for sure.
Hey QF,I talked to snapon customer service last week and the slides are available, but the part numbers have changed from the originals, I will look in the morning and post the part numbers
a lot of the younger dealers don’t want to be bothered researching the part numbers for the old boxes especially since if it is a warranty they are working for free
the replacement ball bearing slides for my other box are back ordered
I know the part numbers are stamped in the slides, my issue was that one part number had been supeceeded and half the slides the stamping was warm to the point that it looked like a different number.Hey QF,
If you can remove a drawer, the Part Number will be on the slide....
I have a couple sets of slides ordered for one of my KR 557 boxes.... along with a "keyed alike lockset"...
The last set took about 6 or 8 wks for him to get in....
Hope this helps.
Later, Mark
I'm guessing the side handle is likely the same one they used for the 557 and some of their other roller boxes. I'll check the measurements on mine. May help you to source another one.The only parts they did not have were the handle on the end of the box to move it and the handle on the back for the drawer.
so I am still looking for both handles
ThanksI'm guessing the side handle is likely the same one they used for the 557 and some of their other roller boxes. I'll check the measurements on mine. May help you to source another one.
This is from another threadThe only parts they did not have were the handle on the end of the box to move it and the handle on the back for the drawer.
