I would check CL all the time too, also went to a lot of garage sales & estate sales. Estate Sales are good to look on CL and if you see good pics of the garage sometimes you can hit gold. Also sometimes there are Facebook Garage Sale groups for your area, you can sometimes find good stuff there.
I found a NIB 8" craftsman bench grinder locally on CL for $50 so I grabbed it since they are pretty scarce around here (bench grinders in general). Rated 3.0A / 1.4HP, it had just about no power. Okay for light grinding but when you stick a wire wheel on it you can stop the motor very easy. Ending up selling it after having it about a week for $75, literally hours after posting on CL.
Found an older model 8" Dayton on eBay that was NOS / NIB. Seller only had stock photo (of a newer model) and a picture of the box. Figured I would take the chance after looking over the specs on the Grainger website. It was $100 + $50 shipping (It was very heavy). So it shows up, new in the box as described... Motor is stamped
1987! And the seller had TWO! I was going to grab the second one but instead of BIN he did an auction and price started going up so I passed. It's a 3/4HP but rated at 10.8A! It is a beast and still scares me every time I flip it on I go running around the corner! But I can wire-wheel anything and it doesn't bog down. I use the stone for sharpening my lawn mower blades, chisels, drill bits, grinding down whatever...
Not too long after I saw on an Estate Sale what looked to be a decent shape CMan block grinder, so I went early and was able to grab it before all the other guys showed up, paid $20 for it. It was a 1/2HP / 5.2A rating... It was rough and needed a lot of cleaning, but ran smooth and was complete. It has plenty of power, but not as overbearing as the Dayton. It runs so smooth in fact I still haven't bolted it down (but I need to).
Lastly I found a little 1725 RPM 1/6HP homemade buffer that I bought for a few bucks. Need to build a little box for it and re-do electrical but it has a good strong motor and will work great for polishing small parts.
I have a couple stones, wire wheels, scotch-brite stripping wheels, unitized deburring wheels, and various polishing wheels. They all have their purpose. One thing I don't like doing is taking off the stones because it can take a while to get them balanced and I'm a perfectionist, lol.
The side-to-side wobble is usually due to the stamped steel washers on the bench grinder. Only thing I can say is do not overtighten! Here is a good link on how to tune up your wheels and remove that side-to-side wobble. It takes a little time and patience. I didn't put paper on the side of the wheel, I just used a pencil and marked on the blotter area. One tip I would recommend is to always have the wheel the same orientation when you tighten it (i.e. always put the text up) because even that can have an effect. I usually start out turning one of the washers 90 degrees at a time till I find the least runout, then use those little stickers to fine-tune it.
http://www.geigerssolutions.com/Tuning-Up-a-Bench-Grinder.html
I've also had wheels that were egg-shaped, you could watch the wheel get closer and farther from the rest as it spun. I bought one of those diamond impregnated dressers on eBay and was able to true it up back to round.
I would take the wheels off your grinder when you get it and see how it runs with nothing on it. If it's smooth then you know any vibration is caused by the wheels you put on, hence the need to shim & dress them true.
Anyhow, my point is, don't be too dissuaded. Some of the best garage sales I've found were never listed online and were actually on the way to another garage sale or I just saw them while running errands. But also Estate Sales can be good for garage stuff if you show up early before everyone else picks it over. I've seen a few good things on CL (including some Baldor's, with stands even!), but they always sold by the time I called...
