Images Not Appearing
hoyt
Virginia Beach
Once again, the images I host myself in my garage thread at
are not appearing, not just for me, but or others I direct to my page. I don't even see the links in EDIT mode. What's up?
I've had this issue before and there was no real resolution to it, things just magically started working again.
Git
S Cal
When your in Edit Mode, click on the two brackets on the right - Toggle BB Code, and you should then be able to see your links
Below is the link to one of the images from your first post in that thread. There are two links, the first uses the url tag, and the second uses the img tag. I don't know why they are not displaying properly but it may be because you are using a http address instead of https?
1. http://shop.maximumhoyt.com/~hoyt/gj/8HqijUll.jpg
Edited to add - from my limited experience, sometimes when you pay for web hosting, there are settings to prevent 'hot links' - your photo's being used on another website where you did not authorize their use, and when people view those photo's it uses up bandwidth at your web hosting site, and some people have limited bandwidth or have to pay more money if they go over a set amount. Are you sure you don't have 'hot link protection' turned on at your web host or some other similar setting
