Impact driver bit set?
BeaterGoat
SW Ohio
Any recommendations for a quality impact driver bit set? I'd prefer USA made, but I'm not sure such a thing exists. Quality is first priority, cost is second. I'm not interested in cheapo bits that won't last long, but I'd like to find something at a reasonable price.
I'd be interested in finding a set that has 2" long bits instead of 1" so I have the option of using them without a magnetic bit holder. What do you guys use and what would you recommend?
mattyrattypoo
Milwaukee impact bits are horrible. They just do not last. The only upside I see to them is that they are available everywhere.
I highly suggest you look into Wiha or Wera. Both are very high quality and will last much longer than anything at the big box stores.
NoahG
Detroit, MI
Makita Impact Gold. Just wish they had real 2" power bits and not those double enders than only fit in their products.
bahcoswed
Sweden
Ohh forgot, do not buy milwaukee impact bits! Made in china and lasts a few screws only!
BeaterGoat
SW Ohio
Just closed on my first home yesterday...money is tight. Trying to balance quality and cost. For 16 bucks I'll see how far the Dewalt set gets me. As finances allow I will definitely pick up a set from Wera or Wiha.
fury9
Mchenry, IlLaHnoYs
I haven't had any issues with the milwaukee bits. I just get the 20 pack and grab a new one when needed, lasts me for a while, maybe I know how to properly drive a screw? flame on....
rodm1
All the Tool and Die makers I've worked with had a quick change bit system on there impacts that whose very very good.
Letsgobowhunting
Village of Clinton, N.E. Ohio
Those wiha and wera bit sets sure look nice but are a little out of my price range. Anyone have experience with Dewalt's impact bits? I'm eyeing this set
http://www.amazon.com/gp/product/B001EYU5OC/?tag=atomicindus08-20
Certainly no wiha or wera, but I imagine they will be sufficient for my use and aren't garbage. Thoughts?
I have used the DeWalt and they are not bad. I am planning to get the high end bits and compare them. I was using the DeWalt to set hardy backer board in a shower and they would shatter the bits. Im not sure if they are or aren't meant for that.
BeaterGoat
SW Ohio
Waiting on the dewalt set to show up in the mail. I used the Bosch phillips bit that came with my new impact driver all day today and I'm very impressed. I'm not sure if it's even "impact rated," but it stood up to a TON of fasteners today and still looks brand new.
nicksnothereman
In the Mojave
Those don't look one piece (might be, I don't know). Impact=get one piece. I agree with the vim suggestion but some of their stuff can be expensive and not sure if US. If you find something cheap enough and use them all the time, maybe get a backup set of the pittsburgh pro (harbor freight). Just a suggestion because most will be mail in type warranty.
I don't find much of a need for impact grade hex (torx somewhat more). If I can't budge it with a regular 2 piece socket I'll use a heat gun/penetrating oil if possible. I had an issue with a stuck hex socket cap near a fuel rail and just went right to hammering the ratchet.
superautobacs
Vancouver, BC
If you're using an 18v impact drill I'd definitely consider getting impact-rated 1/4" bits. An 18v impact drill has too much torque to drive a piddly 1/4" bit unless you have the torque-limiting feature that the torsion zone provides on the impact-rated bits.
There's a fine balance to having the right amount of rigidity and twist. If the balance isn't correct, where there's too much twist, it limits the amount of torque applied to the end of the bit, making the bit less effective in driving fasteners, and making the torsion zone wear out. Too rigid and you get a bit that's prone to cam-out (on a Phillips head bit) or shearing the head right off with all the torque transmission to the end of the bit.
If you're using a 12v impact drill, I won't be to worried about getting the impact-rated stuff, unless your primary use is going to be driving long Phillips head screws into wood, without drilling pilot holes.
