Impact socket set not made for power tools?
ricepudding
So I just noticed today that my 30pc Stanley 1/2in impact socket set says on the case that they are not to be used with power tools. Then it shows an impact wrench with a x over it. I have been using the sockets weekly for a few months now, and they don't show any wear. Why would the case say that you can't use impact sockets with a impact? Weird.
Store link: http://www.canadiantire.ca/en/tools-hardware/hand-tools/sockets/socket-sets/stanley-fatmax-professional-impact-socket-set-30-pc-0589269p.html?utm_campaign=bazaarvoice&utm_medium=SearchVoice&utm_source=AskAndAnswer&utm_content=Default
larry_g
oregon
Are you sure that they are not just a black oxide finish on the sockets?
lg
no neat sig line
OutsideMachinist
Norfolk, VA
Doesn't stanley have black chrome tool sets? Maybe that is what you have, and that wouldn't be for impact use.
That is husky but stanley makes a set just like it. Black tools but not impact.
sqft
If it is an impact socket set, how can it not be for power tools? What other impact tool is there besides a hammer?
Sounds like lawyers doing the BS they do.
scw1991
Guessing Stanley figured it was more economical to furnish a black oxide finish rather than hard chrome to save a few bucks.....
HaroRider
New York
Just because they are black does not make them impact grade.
If the case states "Impact Sockets" then thats just silly.
HF sells 2 different "grades" of impact sockets. The better ones will say "chrome-moly" (yes, they contain chromium despite having a black oxide finish) and the lesser ones will say "chrome-vanadium".
Pass on the CrV ones !
Charlief
That's just a black oxide finish. Impact sockets are made to "wear" and not shatter when used with an impact gun.
Impact sockets are made to transfer more torque to the fastener. They also wear on the anvil opening so the anvil on your impact doesn't wear out or break off.
firebox40dash5
I'm also gonna agree that sounds like "industrial" black oxide finish, but not "impact sockets". I have a few Snap On items like that, a 3/8"-1/4" adapter and my old bellhousing extension. It was kinda a moot point with the bellhousing extension, it's so thin it would hardly transfer any torque with an impact... everything had to be broke free by hand and then I could run it out with a gun.
+1 on Harorider's statement that if they were packaged as impact sockets, that's dumb as hell.
panknuckshovel
Land o Lakes FL
More than likely because it is a cheap lower end set they are telling you not to use it on an impact gun because they don't know how powerful of an impact gun you are going to use.
CNGsaves
KS and OK
Yep . . . . attorneys . . . . stinking fleabags wanting "back door" to get lawsuit dismissed if something goes wrong.
Herod
My mother's basement
May be a misprint on the factory label. Call stanley tools and ask them what's up. What kind of a rotten tool company would sell impact sockets, then tell you not to use them on impacts.....? Stanley used to make ok stuff.
Mechanical Noise
Southeast of O'Hare
I found the Stanley 58-9269-2 set on the Canadian Tire website. Seems this set is exclusive to Canadian Tire.
http://www.canadiantire.ca/en/tools...e&utm_source=AskAndAnswer&utm_content=Default
The socket box looks to be in a cardboard sleeve and in the upper right hand corner there's a picture of some one using an impact wrench on a lug nut. Can't say why the text disagrees with the picture but maybe it's a translation error.
panknuckshovel
Land o Lakes FL
Read the reviews for this set. First review mentions the same warning.
"There is a warning label conveniently located on the inside of the case saying Not rated for Power Tools. Would have been nice if it said it on the outside of the box. Also, it was missing the 19mm deep socket.
I'd advise opening the unit before purchasing it. Returned it today."
stikman56
It isn't an impact set
Not sure why people are saying this, it say IMPACT right under the lid.
I think they're protecting themselves if you break one. Either that or they're really no good and they know it. So many frivolous lawsuits in these times.
LB-1911
Northwestern Il.
http://www.canadiantire.ca/en/tools...e&utm_source=AskAndAnswer&utm_content=Default .
Please contact the following Customer Service groups if you are not in the USA for Stanley Tools:
http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=support.htm&LEFT=left_support.htm
PFSard
Mesa, AZ
I believe the original post did not have the pics. He added them after so many people posted similar statements.
And that sticker is useless for someone buying the product. Unless there is a similar warning outside somewhere.
As others have indicated, what good are impact sockets that you cannot use on power tools. Very limited usage. I'd return them for a refund. And I'd write an email to the manufacturer stating what I see to be an error of their ways.
R
ricepudding
chinese steel. Nothing but the best
Not really, they say made in USA on them. I also have a cheap set of princess auto impact sockets ( harbor freight equivalent), and the stanley ones are much more robust. They also have a nicer finish.
I really don't care if the case says not for impacts. They were cheap on clearance for 30$ so I don't care if they do break.
Virgil Cain
I suspect that the person that designed the packaging simply started from a non impact socket set and not knowing the difference simply left the "no impact wrench" warning. Probably a graphic artist that didn't know the difference.
Tronyadorable
Kinda goofy aint it ? I tested a manual impact one time and it wouldn't undo 300 ft lbs( 3/4" or 13/16 ? nut) no matter how hard I hit it.That's nothing compared to my gorilla *** on a 24" breaker bar. Looks like a Stanley scam item.
Damn shame.
Kirbot
New Jersey
Does anybody even use manual impact drivers on nuts on bolts?
I thought they were only for screws.
My guess is it's either a misprint of some sort, or a lawyer stunt.
