Is it possible to use dynamic mode with a motorcycle clamp adapter or does the adapter throw off the machine? In dynamic mode I just keep chasing weights when I clamp the wheel in a new position. (works fine when doing a static balance)
The instructions are horrific and it's not "motorcycle specific", but the inputs are wide enough to work fine with a motorcycle wheel.
Does anyone else own an import balancer and have you been able to dynamic balance with the clamp style adapter or do need to use a foam pad clamping setup with dynamic. I feel like the tire clamp might be throwing off the machine.
