In a bit of a bind
silverdot1211
I bought a Puma PK6060V air compressor last year. I bought it with the mind set that I would be using it for air tools light sand blasting and of course filling tires and balls and that sort of stuff. Well fast forward to now and I use it quite a bit for sand blasting and in general it gets used more then I expected. I have used the air compressor so hard at one point the plastic line used to shut the compressor off partially melted and blew off. I know the compressor has a 50% duty cycle. To avoid some of the issues I saw I installed an after cooler (after the pump before the tank) and added a box fan. At this point it is just a band aid.
So my question is. I saw a duplex IR type 30 with I believe an 80 gallon tank at the junk yard the other day. I spun the wheel and it was smooth but didn't do anything beyond that. I was thinking of robbing the pump (not sure on the model or size I think it was a 5hp) and replacing what I have.....thoughts?
My concern is that my tank is rated for like 150PSI can I put a large pump on a smallish tank? would the pump head wear prematurely because it doesn't get time to warm up before it shuts off?
At this point I have two things working against me. one funds are tight and two the wife/check book doesn't understand the issue I am at and she refuses to let get another bigger air compressor. As a side story when I bought this one I told her the one I am looking at was bigger then she was. at the point she said "sure what ever." Well when I got it home and she saw how big it was and she got legitimately mad and my tail slept on the couch for 3 days (I seriously slept on the couch!)
I know I am rambling but I have so many questions and don't know where to start. Any help would be greatly appreciated.
plinker
Northern Wi
If the motor you have will have enough power to pull it, the pump off the IR will be fine, but a 3hp motor wont be enough if the IR had a 5hp (just an example).
As for the 150 psi tank, the pump does not control that, the pressure switch does. Likely the IR tank was 175psi rated.
silverdot1211
If needed I think I can find a 5hp motor but was hoping maybe different size pulleys would help address this
scw1991
You could use a 3hp motor. You'd just need to slow the compressor speed down by going to a smaller motor pulley diameter. yes you can put a larger compressor on a smaller tank. Motors are rated with a certain starting code which designates a certain number of starts/stops per hour. If you find you are exceeding this value, you could always install an unloader valve. Same configuration as a gasoline engine driven compressor which allows the motor to run continuously
silverdot1211
So the duty cycle on the compressor isn't for the pump but for the motor starting and stopping? lately when I am blasting the compressor will run almost continuously for like 20 min or better.
