silverdot1211
- Joined
- Feb 2, 2013
- Messages
- 45
I bought a Puma PK6060V air compressor last year. I bought it with the mind set that I would be using it for air tools light sand blasting and of course filling tires and balls and that sort of stuff. Well fast forward to now and I use it quite a bit for sand blasting and in general it gets used more then I expected. I have used the air compressor so hard at one point the plastic line used to shut the compressor off partially melted and blew off. I know the compressor has a 50% duty cycle. To avoid some of the issues I saw I installed an after cooler (after the pump before the tank) and added a box fan. At this point it is just a band aid.
So my question is. I saw a duplex IR type 30 with I believe an 80 gallon tank at the junk yard the other day. I spun the wheel and it was smooth but didn't do anything beyond that. I was thinking of robbing the pump (not sure on the model or size I think it was a 5hp) and replacing what I have.....thoughts?
My concern is that my tank is rated for like 150PSI can I put a large pump on a smallish tank? would the pump head wear prematurely because it doesn't get time to warm up before it shuts off?
At this point I have two things working against me. one funds are tight and two the wife/check book doesn't understand the issue I am at and she refuses to let get another bigger air compressor. As a side story when I bought this one I told her the one I am looking at was bigger then she was. at the point she said "sure what ever." Well when I got it home and she saw how big it was and she got legitimately mad and my tail slept on the couch for 3 days (I seriously slept on the couch!)
I know I am rambling but I have so many questions and don't know where to start. Any help would be greatly appreciated.
