I'm looking for an in the ground pneumatic ram lift. These were used in motorcycle shops before table lifts became the rage. Anybody here got one laying around or know where I can find one?? Any help wioll be appreciated.
If it truely is an "in-ground" ram and reservoir, then it's probably not worth it! The EPA regulations associated with installing an old hydraulic lift are lengthy. Plus I seriously doubt any local jurisdiction will allow you to install it -- unless you live in the country. Also, you'll spend almost (if not more) making an old lift EPA compliant vs. just purchasing a new sealed inground hydraulic unit or modern above ground electric/hydraulic.
One option is the new portable garage lift that BendPak is coming out with. It has a specialized motorcycle lift attachment and looks very promising.
