In-ground Lift.
Rick B.
East Tampa
I'm looking for an in the ground pneumatic ram lift. These were used in motorcycle shops before table lifts became the rage. Anybody here got one laying around or know where I can find one?? Any help wioll be appreciated.
waltmcq
PT
Check Craigslist. I'd check around for a company that does the work on gas stations, the ones that replace the tanks. They also tear them down.
goodfellow
NoVA
If it truely is an "in-ground" ram and reservoir, then it's probably not worth it! The EPA regulations associated with installing an old hydraulic lift are lengthy. Plus I seriously doubt any local jurisdiction will allow you to install it -- unless you live in the country. Also, you'll spend almost (if not more) making an old lift EPA compliant vs. just purchasing a new sealed inground hydraulic unit or modern above ground electric/hydraulic.
One option is the new portable garage lift that BendPak is coming out with. It has a specialized motorcycle lift attachment and looks very promising.
http://www.garagejournal.com/forum/showthread.php?t=24033&highlight=Ultimate+garage+lift
