If all you want to do is insulate your basement, then these panels should work out well. But most times homeowners want to finish off their basement and that means they don't just want to insulate their basement, they also want to put in electrical wiring, a drop ceiling, some type of flooring, set up a video and a sound system, and run the wiring thru the walls or ceiling. To do all that you really want to stud out the walls. If you stud out the walls, then you may as well use spray foam or use 2 inch or 3 inch Styrofoam sheets to insulate the walls.
