In Vintage Eggbeater Drill Press
heyyou
usa
I just had to have this little drill press from estate sale. No markings, looks factory and not homemade Any Ideas to put me on the right path for info on it? 19 inches tall with a Millers Falls #5A Eggbeater in it’ Thanks
crguy
SW Washington
Possibly a cobbled together unfinished project. Where's the downfeed? The pieces that fit on the column look to be made from barstock, not castings as you normally see on factory made drill presses.
H
heyyou
usa
Appreciate all responses so far. Pretty sure it’s factory made with the base and work top both cast iron and or steel. As far as modified electric hand drill press, I own 5 in my collection and no way. I will get the rest of the ZAT number and post as soon as I can. Thanks again
Beerhippie
Far NE Oregon
The base, table and column are factory production--for something else. The rest would be easy to fab given a half-decent shop.
I think the spring is on the wrong side of the table. I can see using up-pressure rather than down for the feed. Having the spring between the table and the head makes no sense.
WisJim
Menomonie, WI
I don't see any mechanism for feed or down pressure, unless it's obscured in the photos. I would think that a factory made device wouldn't use all those cap screws to fasten bits and pieces together.
