Induction rangetop replacement.
N_Jay
Has anyone replaced the glass top on sn Induction range?
Got a deal i could not pass up on onw with cracked glass
mm08822
Check a site like appliance parts pros. They do many repair videos that are quick to the point.
dcg9381
Austin, TX
curious how this goes.. We've got a slightly cracked top (contractors) and I've been living with it. Part was on backorder for a year..
N
N_Jay
What brand and model?
Parts place says a couple of weeks.
Videos make it look like a 20 minuet screwdriver job.
75gmck25
Alexandria, VA
I was searching for parts for my Fisher-Paykel dishwasher and there was widely different parts availability times from different suppliers. Also a lot of difference in shipping cost. I would do some more online queries, and also call some local suppliers.
dcg9381
Austin, TX
Thanks. Little better over on searspartsdirect and one other place.
I have found videos on replacing the glass for standard non-induction stoves, but have not seen a glass replacement on an induction top.. That's what's got me paused at the moment. Might be "close enough" The Whirlpool video makes it look pretty easy.
Note, I paid for this once - even lower, but never showed....
N
N_Jay
Top came in, took about 1 & 1/2 hours to disassemble and reassemble the range.
So now I have a $1400 induction range for about $500.
Kitchen remodel stars in a couple of weeks, so it will be a while before I can test it out.
N
N_Jay
To add a little clarity.
It took 1 1/2 hours because I was going realy slow and carefully.
Some parts if the design made service easy, while a few other things are a but of a PITA.
The top (almost) comes off with 6 easy torx screws. Then you realize you have to pull the back off to get to the electrical connectors, since the induction elements are in a module attached to top.
Well, the module just unclips, withe the glass down (module up), but then you find you really need to flip it over before taking it apart.
Of course, glass up makes the clips nearly impossible to get to.
So you unclip it, the carefully flip it so none if the clips reengage, then lift off the glass.
Easy Peasy!
Re-assembly is the reverse of disassembly. ;)
