Inexpensive adjustable pressure switch for air compressor?
goodysgotacuda
DFW
I have a Charge AirPro compressor [20gal, 9.4scfm @ 90psi; 220v] that has a static pressure switch that I find annoying. It runs up to 125psi like a good switch, but it doesn't seem to kick back on until ~85psi or so...which is a bit low for me.
I run my air tools as max psi and at 85psi or so..they don't do what I want, with that huge pump on a little tank, I'd like to kick it back on at ~100psi.
Any suggestions for a 220v adjustable pressure switch that doesn't break the bank? I don't deal with much a/c electrical, so I'm a bit lacking in my wiring knowledge when it comes to that...hopefully just a swap terminals kinda deal.
Thanks!
Jbullfrog
Avoca, Iowa
Get a bigger tank. Pressure switches are not something for a novice to start tinkering with. You can cause alot of damage or get hurt.
PT Doc
Condor makes pressure switches that are used by Quincy. I'm sure you can find what you want from a place like Graingers.
