Initial Paint Booth Plan?
ctandc
This will be for painting motorcycle fairings / tank etc and small parts. Because of time constraints, I'll be doing only one piece at a time.
This a rough drawing, and definitely not to scale.
I plan on making a frame out of PVC or Wood. Using plastic to enclose it. It will be about 8 foot tall as well. So it will be pretty much full enclosed.
I'll use a piece of plastic with velcro for an access door.
I'm assuming it will be an attempt at a positive pressure booth. I plan on using a box fan to push the air / fumes out of the booth / garage and away from the house. I'll use at least two furnace type filters to filter the fumes as the go our the door.
I plan on putting enough thought / time into the design / build of this, so I can easily store it and put it back up for painting other things in the future.
I would think a frame to hold the fan would work, as well as a frame to fit flush (as possible) up to the door so I can keep the majority of the fumes out of the garage and away from the house.
Will a normal box fan provide enough air for this small booth?
I plan on making a 'roof' frame so that I can hang parts and also hang a cheap plug in flourescent light like this:
Any issues with having the light inside the booth?
Is it safe to have my oil-filled electric radiator type heater inside the booth to keep the temp where I want it, or will just near the booth be okay?
Thoughts? Feedback?
Is the 35ft (from the door where the fumes will vent thru the filters) to my neighbors fence enough?
I won't be painting but a handful of pieces, and more than likely one at a time, so I wouldn't think there would be that much coming out.
Thanks for all the help.
trainer
Northern Ontario, Canada
I think alot of this depends on the type of materials you'll be spraying and how close your neigbor's buildings are to the fence.
you definately want positive pressure ( fan blowing into the booth, not out) or else it will **** dust in from every little opening. This also keeps the fan in clean air.
I'd do something to cover that light so a tube doesnt get broken when your in there.
79firebird
Victoria bc
yes fumes will vent thru the filters run a vent stack abofe the room like 2 feet and it should be fine. The heater you shouldent use in there well paining after the fumes is gone it will be ok . For lights if you go above the plastic it should be fine but below it it should be explosion proof. Just use a proper fan for the venting ive seen meany cheap wallmart/ canadian tire fans start on fire from people painting with them.
dps
Even a "real" booth wouldn't use positive pressure, much less one made of flexible materials. They are called exhaust fans, not intake fans because they operate on negative pressure. There are several threads here you can search on temporary set-ups.
For the neighbors (or yourself), the wind direction is going to make the difference unless you go with a more powerful fan and a vertical stack exhaust.
