racecougar
Does the landlord have any idea what electric bill he/she is in for once all five tenants install AC and let it run 24/7 without insulation? Whew!
One of my customers installed mine and that is what he told me to do. He said to not even bother turning it up or down. Same with the heat. So I dontMy plan is to keep the AC going 24/7, but maybe with the thermostat at 80? Then when I'm there wrenching I can turn it down.
When I installed, I found that 2 x 24K units were less expensive than a single 48k unit.Ok, so I'm going to go with a pair of mini-splits. The only issue at this point is whether I go with a pair of 2 ton units for $1,100 each or a pair of 3 ton units for $2,000 each.
Absolutely, but some of us don't pay attention to heating in Texas until we figure out that some of the Daikins don't do well below freezing. I was so focused on cooling, I didn't even consider the heating side of it.That depends on the unit you buy.
I like the idea of 2 units, especially on applications like this where you may need "hurry" cool down, but can run one unit to maintain temperature.
You may find (as I did) that when it's really cold in Texas (you know, 2-4 days every 2 years) that your heat pumps will not keep up... So just be aware.
And also, how much does electricity cost per kilowatt-hr?Just out of curiosity, Whats something like that rent for a month?
This is what I have also for the same reasonsThat’s what I have. It sorta allows you to have multi stage. In the fall and spring running 1 is sufficient and works better to remove the humidity than a bigger one running short times because it’s reaching its set point temperature.
I kind of wish I'd gone with open cell under the roof. Closed cell does nothing to dampen the rain noise.I have a 36x32 shop with open cell foam and triple-insulated doors. 36k senville (2- 18k units) and when it's close to 100 degrees outside I can almost get it to 65 degrees.
The sun is on the doors around noon and it seems to not bother the garage.
I'm in Tennessee.
3 ton, if you build later you'll have a good start in the hvac. That first year's lease and A/C is a chunk of dough. Does each shop have its own power service?Ok, so I'm going to go with a pair of mini-splits. The only issue at this point is whether I go with a pair of 2 ton units for $1,100 each or a pair of 3 ton units for $2,000 each.
They'll both be mounted on the back wall; that's really my only option since I'm in the middle unit and I can't place one up front. The outside unit will be on brackets above the ground a few feet.
Any thoughts on 2 or 3 ton?
Thanks,
Scott
My 24k mini splits spec a max 30A breaker.The power is potentially an issue. There's a 200A box on the back of the building that services all 5 units. Each 20' x 50' unit has a 125A box.
I'm not an electrician, but I think the main box should be 400A. Thinking about installing a 200A box in my unit, but not sure that this makes sense given the 200A box for the entire unit.
Thanks
For a general shop - I can't imagine you'll ever need more than 125A. I've got 100A going to mine, and never have issues.
That's another 2 panel slots for the two-pole 240V breaker. For power, look into what machines and equipment you have now and also what you might add on soon/later.
Two minisplits each with 30A 240V double pole breakers is four panel slots right there.
Air compressor, anything 'decent' and you are using another two panel slots for a 240A breaker.
Welder? Another two slots for the 240A breaker.
Lighting? Suggest at least separate two circuits.
Utility or general use outlets? Again, at LEAST two separate circuits.
Already up to 12 slots in the breaker panel.
Landlord paying the electrical? Put in an EV charging station.That's another 2 panel slots for the two-pole 240V breaker.
Make sure you have enough slots in the panel! Some 125A subpanels only have 8/16 slots.
Barring trying to run a big old transformer-based 'industrial' welder, you can run a big/decent 'modern' welder on a 50A 240V breaker. Again, short of full-out 'industrial' type stuff.
Two minisplits on 30A breakers should be max 24A draw each. That's 48A right there.
Air compressor kicks on, maybe another 24A for that (not counting in-rush current when the motor first kicks on).
And you are welding at the same time. Maybe another 20A there if you are running the 211 hard.
That's about 90A current being pulled just there. And that's a use case easily done by just one person in the shop. With no lights or other things being run at the same time. Air fan to blow some air around to cool you off or get the welding fumes away from your face, a fridge for a cool drink, etc.
125A doesn't necessarily go that far when you add in HVAC to the shop space and just a couple of amp-hungry devices like a welder and a bigger air compressor. Just an FYI and to be aware of how quickly the amps can add up even with just one person in the shop.
You can get open cell sprayed on top. That's what I did and yeah, made a huge difference.I kind of wish I'd gone with open cell under the roof. Closed cell does nothing to dampen the rain noise.
Fair warning that will be an issue if you ever do plasma cutter.Thanks for the input. Will likely need to unplug the compressor while I'm welding.
If I read the OP's post correctly, I believe he paid $960 for the install. Still quite cheap for the install of two units. Though that install is about as easy as it gets.3 guys, 4.5 hours for $480? Sounds like a deal.
That is a JOKE for insulation in TX ! For a metal roof in TX, you need at least 6" of insulation, 12" better !
The backing boards look square and the units appear to mounted symmetrically relative to the breaker box and outside as well. That's a good sign.
You can cool it, but you will need a MUCH LARGER A/C !
I've got 2" of closed cell all over in my 40x50 with two 24k units. It works great. Laser thermometer on the inside of the roof shows ~80-81 degrees with outside temps in the mid 90s. It's also a white roof.I really don't think I will need a larger AC. The HVAC guy thought I could have gotten by with a single 3 ton unit, but I went with a pair of 2 ton units instead.
These are the same units I have. OSB will be fine. The interior units aren't very heavy.Pallet of stuff showed up a few days ago from Amazon.
HVAC crew showed up today to install. Three hombres, but not a ragtag crew. Had the requisite tools and equipment to complete the job. Price to install each unit went up from $350 to $480; according to the boss, they needed more supplies than they expected when they installed a pair of 24k units two doors down.
Not a huge fan of the particle board they hung the inside units on, but if it looks like it's sagging, I'll either brace it or replace it with 3/4" plywood.
Took them about 4.5 hours to complete the job. Install looks fine to me, they cleaned up after themselves, and both units working fine.
It was 97 in the shop before the install - hot, but not unbearable. Some air circulating would have made it much better. Anyway, temps dropped to 90 before I headed to the house, but if I stayed in the area where the cold air was blowing, it was quite comfortable.
Yea, that's cheap. Takes me at least 6 hours to install one of these in a shop.If I read the OP's post correctly, I believe he paid $960 for the install. Still quite cheap for the install of two units. Though that install is about as easy as it gets.
Congrats! I love having the cool work space.
