(I put this in the wrong section. If someone can move it to the Electrical/Lighting section for me I would be most appreciative. )
Finally got the wire run from the house breaker panel to the shop and was pretty impressed with my efforts as I got it done and didn't electrocute my self in the process. I figured I would have something to fix because that's just the way it works with me. Inspector was OK with my connections in the boxes but he stated the wires in the wall from where they come through to the point they enter the box need to be protected with a flexible conduit type of material. I know he said what it was but I can't remember what he called it. I'm not too concerned with the run in the house as I have a lot of room to play with due to the 6" studs. Should make it semi- easy to make the bends. But the shop was done with 2x4 suds and I'm thinking making the bend is going to be a PITA and I'm thinking the conduit/wire will protrude out past the edge of the studs making the sheet rock bulge in the area.
The inspector told me that he doesn't do much residential inspections and that he is mostly doing industrial stuff. Not sure if there is a lot of differences in codes for the house vs. industrial but I'm thinking there is probably some huge items.
Anyway, I'll add a couple of pics for a clearer idea of what I have and I'm up for any suggestions or ideas. (I'm off to the store to price the conduit and fittings. Anything to make the inspector happy so he will sign me off)
Earl
First shot is inside the house. The vertical wire close to the stud is the power going out to the well pump. The wire off to the right is the ground for the shop. I didn't know all the wires need to go through the same hole in the box. Oh, I forgot to put the metal plate on the stud to protect the wire from nails or screws, but he didn't say anything about that.
Second shot is the panel in the shop. This is where I'm worried about the conduit making the 90 degree bend up where it comes through the wall. 2x4 studs don't give me much room.
Earl
