Jeeper
Over the last weekend, I finally installed most of my 3/4" Maxline airline kit. I got it last year for father's day and finally got around to installing it. Didn't want to rush into it or anything.
Overall, I am impressed with the kit. The connectors that seal to the tube work great. It bends easy enough. You do risk kinking it if you bend too much one one spot. So far I did one main line from my compressor (it sits in a storage room next to the garage) up into the attic then to a drop on one wall and tees over to a hose reel that is also in the attic but drops down through the ceiling.
I am chasing at least one leak which is next to the pressure regulator. I didn't want to tighten the fittings on the aluminum body of the regulator too much and it's causing a leak so will have to address that. I also have plans to put 2 more drops. One by my work bench and then one in the front by the garage door. But for now the reel is the big win as that is what I will use the most.
Some pics..
Compressor and regulator:
Hose reel in attic and through the ceiling (eventually will be drywalled):
Some pics..
