Installing a motor on a HF bead roller
37ford4dr
Arlington Va
a little diversion.....i have some sheet metal parts to make for the MGA coupe and since little joe went back to college i need another set of hands....or a motor
original mods on bead roller
http://weldingweb.com/showthread.ph...any-deflection&p=3557431&posted=1#post3557431
heres the install materials: mometary foot switch, dayton gear motor which spins at 2.8 RPM, reversible drum switch, and a vintage crank for creating tension, jaw coupling from McMaster Carr
the old business end a 25mm shaft on the crank
an already beefed up HF bead roller which doesnt deflect
the mock up using a hose clamp to keep everything together and lined up
wiring
"power in" is the power cord white and black
mocking it up to weld
cut out of 1/8" sheet steel
the offset was just where ever it landed but it is parallel to the bead roller
drum switch mounted
test run to make sure everything works right
it works perfectly tomorrow it gets disassembled and painted then the final wiring and the tension crank gets added
larry4406
Northern Virginia
Nice details.
Can you add a part number details and source for the drum switch, pedal, gear motor, and coupling? Building one of these is on my long list of things to do.
37ford4dr
Arlington Va
the drum switch, foot pedal were Ebay items from China, i will get the other numbers. the coupling was from McMaster Carr. and you order the shaft size you need, i can get the numbers buts whats more important is the concept with the coupling since your shafts might me different sizes.
to me the coupling was the easiset way to go so there are no chains, sprockets etc...
37ford4dr
Arlington Va
finished up the mock up and painted it.
cuts 18 really easily
16 ga was a little more labored but it still did it but was an issue
heres the motor information
final wiring
final reassembly tonight
37ford4dr
Arlington Va
cool project. not going to be much of the original roller by the time you're done. lol
thanks guys and yes you are right on that account.... but still several hundred dollars less then buying one with a motor on it. funny thing is that when you do a search on this motor its application is for bead rollers. this was a fun project and i like doing things i havent done before. the HF unit puts you off to a really good start. bob
