I'm working on a kitchen cabinet install where I'm enclosing the fridge with fridge panels. There will be a 33x24x24 fridge cabinet above the fridge. To the right of the fridge (when facing it) there will be a drawer base and a 12" deep upper cabinet. To the left of the fridge will be the end of the kitchen. 3" of wall after the fridge panel is installed. The wall isn't perfectly plumb. An 8' level touches the wall at the top and the bottom, but the wall bows away in the center of the level.
Right side: My drawer base is 24 1/8" off the back wall. Should I just cut my panel at 24 1/8" so I can flush up with the face of the drawer base? My panels are 30"X96". That means I'll have to shim out the over fridge cabinet. I not worried about scribing the wall to the back end of the fridge b/c I'll be installing a tile backsplash.
Left side: Once the over fridge cabinet is installed, I think I just need the left panel to flush up to its front edge. But I also need to scribe the wall b/c the panel is exposed. How do you guys go about scribing the wall and getting the correct panel width? To attach the left panel to the wall and the floor can I use small metal L brackets? This is in addition to screwing the panel to the over fridge cabinet.
Thanks
Thanks
