Installing windows in existing pole barn
kohner
Northeastern Indiana
First of all I apologize as I would have thought my answer would have been in the archives, but I have spent several hours on here and youtube without an answer. I recently had a 64x40x12 barn built. I did not have the builder install windows as I felt I had enough experience to do it myself. I don't have any issue building the frames for the windows, but where I need a little advice is where to cut the siding. After I build the frame do I mark the outside of the frame on the siding and cut there which would leave the frame exposed to the exterior and allow for easier install with the nailing flange. Then just use J channel to cover up the nailing flange? Thanks for any advice.
16again
Boynton Beach, FL.
Metal, vinyl siding? If it’s removable for a perfect cut I would do that. If not, build frame and drill a hole in each corner all the way through so you know how far to cut back the siding. Yes J channel will be needed. Might have to install the J channel and then a 1x2 to cover the flange and then trim in aluminum to cover it all.
K
kohner
It is typical metal siding on a pole barn and I didn't think about removing the panels to cut. That actually makes a lot more sense now. Thanks.
csp
Franktown, CO
Edit: Wrong video posted earlier.
Pulling the panels would be easiest to cut. Video below is a great example of how to trim it out before re-installing the metal panels.
