zekeymonkey
So, I've started towards getting a pole building built. I just realized that I'm not 100% clear on the correct way to install the gravel under the slab. I'm not sure if the gravel is just put between the splash boards or the area within the building should be dug out and filled with gravel.
Option 1
View media item 44387
Option 2
View media item 44386
Is one of these configurations correct? Is there another option I am missing?
Also, should I put some gravel down where the building will set before it is put up?
Option 1
Option 2
