adamant118
- Joined
- Feb 24, 2015
- Messages
- 39
Bobby I'm not sure yet I am still in the thinking mode. foam insulation that you used didn't insulate well? How are you heating your building? And thank you for your replyyou could spray foam but that costs,i checked into the kits sold on the web to do it myself
but i decided on rigid foam board from lowes....i used 1 inch as a cut/cobble set up,then used another course over that.
will you be finishing wall surface with anything...plywood...sheetrock?
Sent from my SM-G930T using Tapatalk
I did one inch foam board sealed with right stuff foam.
Then I'm going to build 2x4 walls to hang insulation off of.
....blazinzuk-that's the same job i did with the foam boards....did you have any trouble's getting it behind posts and into corners? i had to persuade it some with a block of wood and a hammer....
Wingrider. Please keep me posted on your updates.. explain your situation?
My quote was for 3” on the walls, and 4” on the ceiling. I do not plan to put in a false ceiling, so the tin would be sprayed. That quote came back at $14,400. If I wanted to go with 3” all the way around, then I could deduct $2100.
From what I've always been told anything over 2" of sprayed closed cell foam was not worth the money. Our shop has about 2-2-1/2".
Interesting! Perhaps I should have them rebid the job using that as a possibility.
I am curious about those that put ridged foam on first. Is 1” of foam cheaper than 1” of spray foam?
Interesting that you have asked this question, as I was just going to start searching for what folks have done. I have received one quote so far for spray foam, and it is certainly a healthy quote!
If you want an economical, cost effective insulation job, use cellulose. There's a manufacturer nearby in Loretto. They can ship it to you. See my build thread for what I did. If you would like, I invite you to stop by and see mine. I'm in Dayton.
It's not that thicker spray foam isn't good. It's just that it's not cost effective since the outer 2 inches or so does most of the sealing and insulating. Going thicker than that just means you end up paying a bunch for foam that really doesn't have to insulate much.
Rigid panels are very likely to be cheaper than spray foam at the same thickness. Spray foam is usually priced per board ft (1 sq ft, 1 inch thick). So a 4ft X 8 ft rigid Foam panel 1 inch thick is equivalent to 32 board feet.
Closed cell spray foam is polyiso, so it should be compared to polyiso sheets.
Menards currently shows a 4'x8'x1" foil faced polyiso sheet for $18.65 after rebate, or about $0.58/ board ft. It's r6.
$1/ bd-ft would be cheap for closed cell spray foam in my experience, and it can easily be in the $1.50/bd-ft range. So the rigid foam is likely to be nearly half the cost of the spray foam, and perhaps closer to 1/3. The spray foam will stop all drafts and air movement, but you can probably get more r value for your money with rigid foam. Let your budget and priorities decide.
Personally, I went the route of 1.5 inch rigid polyiso foam between the girts to block most of the airflow and dampen some of the noise. Bought them for $15/sheet on Craigslist, which was nearly $10/sheet cheaper than anywhere else. The r value has probably settled to about r8 or r9 by now. I'll frame out inside of the walls and use r19 batts for the rest for a total near r28 in the walls, and it might feel better than that since the foam should reduce air movement through the fiberglass.
It might also be worth putting a moisture barrier like Tyvek up befor you do any insulation.
Interesting! I seem to recall reading about the dense cellulose being sprayed on the walls. I didn’t recall if it had to be covered once it was “blown in”. I am guessing that it may not be optimal for the roof. I don’t plan on putting in a false ceiling in this one.
Did you cut the foam to just fit tight? Any other means of attaching it? Just getting ideas to do mine.
This isn't sprayed on the walls, but blown in behind netting. Then the wall covering goes up, either drywall, OSB, or steel panels.
Why no ceiling? That's the only way that you're going to get optimal R value and keep your building warm in the winter, and cool in the summer. Don't forget, this is Minnesota. We are blessed with up to a 125 degree temperature spread.![]()
I have been giving some thought to a ceiling...but I still am not certain about putting one in. My trusses are 8’ on center...don’t know of to many products that will span that. I realize I would have to add something in to span it...just money we don’t have in the near future.
Also depends on what the Bottom Chord Dead Load (BCDL) rating on the trusses are. Unless its >=5psf I wouldn't hang a ceiling.
Call whoever put it up and find out what the loading is.I agree... thought about that last night after writing my post.
