Insulating the Roof Deck
cls89
Southeast Michigan
I have a detached garage. I've insulated the walls. I still need to insulate the ceiling. The problem I have is that the spacing on the ceiling joist (horizontal surface that is parallel to the ground) aren’t standard. Please see photo for example. The gaps are pretty significant, so standard insulation wouldn't fit the openings. This is a 20x32 garage, so trying to correct the framing would be expensive time consuming.
The other option I can think of is to insulate the roof deck (sloped surface). However, from what I've read this isn't good practice because moisture can get trapped in the insulation when snow melts, rain, etc. which could lead to mold and premature failure of the shingles and framing. Is there any way around this? I came across a post where someone installed a ridge vent (see link) and then faced fiberglass insulation over this vent. Is this a good option? Are there any other options that I am not aware of? I would imagine a lot of people have this type of challenge when it comes to insulating a detached garage. I am just curious what some of the solutions are to this type of situation.
billconner
Thousand Islands NYS
I can't quite tell what's going on but install a ceiling - maybe metal liner panel - and blow loose fill on it.
What's climate? Will you be heating? We can talk about venting and vapor barriers if necessary.
C
cls89
Southeast Michigan
Wouldn’t the metal panels sag? In some cases the span is over 48”
Climate is Michigan. I would like to at some point get a electric heater.
75gmck25
Alexandria, VA
During a recent renovation I had the roof deck on my house insulated with open cell spray foam, and its getting to be very common in this area. I also had them build an enclosed/conditioned crawl space it also got spray foam.
They have apparently resolved any moisture issues, since neither the renovation contractor or the roofing company had any issues with it. The crawl space did require positive ventilation that circulated air to the rest of the basement, or installation of a dehumidifier.
C
cls89
Southeast Michigan
Also if I run furring strips across the ceiling joists am I limited to metal panels for finishing the ceiling or would I be able to use drywall, plywood, or even PVC liners?
C
cls89
Southeast Michigan
Either 16" or 24" on center, depending on the material you are using to finish
Insulation would ether be fiberglass batt insulation or spray insulation and the finished panels I’m undecided. It could be drywall, plywood, or metal panels.
This is one concern I have. Since the ceiling joists are spaced far apart will loading the joists with insulation plus drywall / some type of finished panel cause structural problems / sagging or will the furring strips add enough rigidity to support the drywall and insulation without any problems? Thanks
mike93lx
Richmond, VA
I wouldnt use 1x for a 48" span. At those distances, I'd use 2x4 for furring strips if drywalling. That said, I believe metal panels would be fine for that span
C
cls89
Southeast Michigan
I figured 2x4 would be better for rigidity on large spans. I just thought it might be too heavy and cause load problems.
