cls89
I have a detached garage. I've insulated the walls. I still need to insulate the ceiling. The problem I have is that the spacing on the ceiling joist (horizontal surface that is parallel to the ground) aren’t standard. Please see photo for example. The gaps are pretty significant, so standard insulation wouldn't fit the openings. This is a 20x32 garage, so trying to correct the framing would be expensive time consuming.
The other option I can think of is to insulate the roof deck (sloped surface). However, from what I've read this isn't good practice because moisture can get trapped in the insulation when snow melts, rain, etc. which could lead to mold and premature failure of the shingles and framing. Is there any way around this? I came across a post where someone installed a ridge vent (see link) and then faced fiberglass insulation over this vent. Is this a good option? Are there any other options that I am not aware of? I would imagine a lot of people have this type of challenge when it comes to insulating a detached garage. I am just curious what some of the solutions are to this type of situation.
