Hi everyone,
I got a barn that I would like to insulate. The temperature here can dip down to 0F in January. I took some pictures of the inside and outside. I want to know if I am tackle this insulation job the correct way. Am I going to trap moisture inside the wall? The extierior is finished with Sikken stain. There's batten between the pine board to seal up the crack. There's no vapor barrier outside because there's no siding. Here's what I did inside. I stapled Typar inside the wall stud. I think this will prevent water from sipping inside the insulation. Then I put Roxul insulation inside and I plan to use wood board over the insulation. Do I need to put poly sheet over the insulation as a vapor barrier?
