Dave Maxwell
Getting ready to insulate my metal pole building. It's 42x72x16. I have a quote for rolled batts of unfaced fiberglass. Should I put plastic on outside walls before I put the stuff in and also what is best way to hold it in place? It is 48 inches wide, so I will need two pieces plus an extra 6 inches between my post. Do I put slats across opening or something to hold it up? Also it's 6.250 thick. My cavity is 6. Was told not to compress fiberglass insulation or it will be useless. Will that little hurt it in any way. They said it is R19.
Thank you
Thank you
