interesting china cman issue?
krdiesel03
Farmington NM
Was board today and thought I would stress test some 3/8 extensions. I have access to a torque wrench that will go to 5000FP. It will also tell you what torque a fastener failed at. I put in a 6 inch MUSA extension and it broke at 230, the china one went to 290. thought it was strange so I tried a snap on, it snapped at 195.
Now I need to go collecting some more extensions and see if it is repeatable.
K
krdiesel03
Farmington NM
Will have to save up some cash, I am not sure about pawn shop tools, you do not know the history. Snap on will not warranty anything used at the plant, Plus i do not feel right warrantying anything that I broke on purpose.
rsanter
visalia ca
You also have to look at the type of failure. Did they all suddenly snap? Did any of them yield then twist to failure?
Bob
scaron
ypsilanti, michigan
that all said, i suppose it could be argued that 200 ft-lbs is a fair bit of torque for 3/8" drive...
edit: though i _would_ be curious to see how other makes come out in the comparison, too.
K
krdiesel03
Farmington NM
yea I am a big guy and there is no way i am going to get 200fp on a 3/8 ratchet.
My point was that the china tool was comparable to the MUSA. I am not hung up like some people about COO. I do not have to worry about my job being sent to china :) and if you look at ipads they can do quality
retDAC
near Huntsville, Ala.
Not surprised at Craftsman, both US and Chinese, doing well but would have expected better from S-o.
LXCam
That's very cool for you to do this and share the results. And I say this not to under play your results. But as was pointed out, knowing if it snapped verses yielded then snapped would make the difference for myself. I'd much rather know it maintained it's torsional rigidity. Reason being fastening of torque to yield hardware. Not long ago someone posted a article regarding ratchet failure tests, the results were interesting like your test. Hey if you feel like testing 3" extensions, for some reason I got a bunch of them from different manufacturers. You're more then welcome to break to your hearts content, I just need an address.
HighPlainsWrencher
This means nothing at this point. You have the torque value that they failed at but we need to know what caused them to fail at that value. Really the only thing you proved with this is that you can break different manufactures socket extensions with enough torque applied. The more detailed pictures you can post the better.
scw1991
If this wrench can measure up to 5000 FP, what is the degree of precision at 200 FP in % deviation at any given point? Did you use a test-lab type torque wrench? What is the make/model?
Hootbro
Delaware
Me thinks had the Chinese Craftsman extension came out on bottom in the test and Snap On on top, people would not be so critical and making a hullabaloo about the testing procedure.
monomach
Illinois
Wouldn't matter if Snap-On themselves did the test and had the results came out like this. Some people absolutely will never accept that any asian country is capable of wiping its own ***, let alone producing even a moderately acceptable tool.
Then again, tool snobs have always hated Craftsman. I made a living with mine back when they were almost all US made and other guys in the shop were still talking **** about how my tools were trash and how Craftsman hadn't been any good since the 70s...anything to justify their decision to hand their firstborn child over to the Snap-On man.
For my part, I've still only ever broken one CMan tool. It's amazing how using the right tool for the job keeps your stuff in good shape.
Hootbro
Delaware
I am not really trying to start a debate that the Chinese Craftsman stuff is better, just that I think the OP did a fair test with no ax to grind and the results just put some peoples perceived bias off center.
The lack of pictures does not help for those that cannot grasp or conceptualize in their brain what he did and the results he conveyed by text. At a minimum, a picture of the broken extensions would alleviate some of that concern.
To put in context though, 195 ft lbs is still respectable for a 3/8" extension and never something I would remotely go to in that drive size and would bump to the 1/2" drive for those torque values.
monomach
Illinois
I don't think anyone's going to claim that the Chinese C-Man (or even the US) is better than Snap-On. Just that it's at least "ok" and not pot metal that folds in half every time you touch it the way a lot of people on GJ pretend it is. :lol_hitti
woody 73
The Great State Up North
I am not surprised by the test, because back in the day before some of the GJ members were born you indeed had Chinese pot metal. Today things are different there are some very well made Chinese and Taiwan tools out there.
I realize that a pro wants a tool that will keep on going 24/7 and they stay away from overseas tools, while others buy what they can afford without going into debt for the rest of their life.
Funny thing but about two months ago at a garage sale I bought a small tool box with tools for $15.00 dollars and one of the tools was a K mart special 3/8 ratchet from Taiwan. That sucker is so nice to use; in the past I would have never given it a second look, but I thought what the heck try it out and now I like it very much.
So good work on the op's part:beer:
Wakefield
Arlington VA (but would like to get out to country
Was the extension that dissappointed older/more used than the other?
I think my old Craftsman stuff strong except for the ones obviously not made well like some wrenches broached offcenter but don't trust the newer ones as much.
Did the extensions bend like butter or like a spring before breaking? Would be easier to tell with a long extension. Butter-bends/twists and stays that way if you let off the torque before it goes bust-Spring-it twists itself back straignt when you let off
K
krdiesel03
Farmington NM
I was not watching close when they broke, Standing back a few feet. I heard a SNAP and then the machine stopped. It was me just screwing around not a scientific test. Next time I will take photos.
TheGrooveking
An alternate reality in a parallel universe.
In regards to an of these snapping and at what torque I am more concern in mnowing what the standards lost as required strength, from there is what would determine which brand is was meeting the specs. Another point of interest would be size and weight, if the Snap On had a smaller diameter cross section at its center length point thus it broke at a torque proportional to the Craftsman.
TheGrooveking
nicksnothereman
In the Mojave
Dude, you're going to get banned on here saying stuff like this.:lol:
nicksnothereman
In the Mojave
I will make that claim!:lol:
(I'm just joking, don't send the snap on truck after me)
Still...um...that's 95 foot pounds difference. That ain't minor bro. Less china is good more snap on needs to up their game.:lol: Flame shield on!
cburnscrx
Indianapolis
I would just like to thank you for doing the test. I think it was interesting, and while I am not a fan of Craftsman moving to China, I am not surprised to hear they are decent tools. :beer:
sberry
Brethren, Michigan
It doesn't surprise me, as someone said, you don't know about pre existing stress and duty cycles though. China has some of the most modern steel mills, lots of older USA was built from old mills with marginal QC.
I know this, 40 pc 5$ socket sets were junk but there are a lot of extensions from those floating around still in service.
Gert
Netherlands
Thank you for testing and posting the results :thumbup:
Please keep us updated on further tests
bobcatdan
Kaukauna,WI
Extensions are one thing I never got too excited about. You are doing something wrong if you are applying over 100 ft lbs to a 3/8 extension. About the only issue I ever had was a 24" import extension that had noticeable torque loss. Bought an SO, problem solved.
TAMPAGT07
Palm Harbor, Fl
I've never made a hullabaloo...How would I go about making one? Any special tools neeed? Just kidding (As usual.) :beer:
Hiball
Missery
It would be awesome if someone had the capabilities/experience/time to scribe a straight line on the extension, and then video the test. I would like to see how much twist is involved at the above torque levels. I suspect the tools breaking point (Especially at the levels given by the OP) isn't near as important as figuring out how much torque is Lost/Applied to the fastener because of the Twist.
Thanks for the Results OP, But we got to have some sort of Pictues.. Or? It didn't happen.. Ha.
Steevo
43.49600, -112.04300
You really need video, preferably high-frame-rate, not photos, that way you can have it running, aimed closely at just the extension, and by slowing down the playback you can see where it flexed, twisted, fractured, etc.
TAMPAGT07
Palm Harbor, Fl
Kinda like in a ***** flick.......:lol:
