REDSKY49...........
You hit the nail on the head.... I know Regal Very Well.. They have been around for years, but............. a lot of their claims are BOGUS ! !
As a 30 year insulation contractor, I used their material ONCE and only ONCE......... Like anything else, there are good and bad mfgrs., and there are also more bad contractors, than there are good..... A lot of them just blow smoke.......
Guyes, believe what you want, but
properly installed BLOWN IN INSULATION will not, repeat, will not settle.. If you open a wall and find no insulation at the top, that means only one thing, not enough was put in, at the time of insulating.. Yes
COMPACTED INSULATION does lose some R-Value, but it is minimal, unless your stacking "stuff" on top of it in the attic....
Example of wall..... I built an 8x8' wall section, with drywall on one side and plexi-glass on the other... Drilled the drywall everyway you could think of Hi holes, low holes, 1 row chest high, big and small holes.. Then we tapped the "wall" section several times.... The installation "by the book" did not, repeat did not settle.........
