Just got a 5hp 3 phase air compressor and am converting to 1 phase. I was told this compressor was running when removed.
Can not find any data on my specific model the "H" and the "x3" are unknown to me and a internet search turns up nothing. Anyone have a manual with the specs or know where to get one?
ordered motor 1 ph 5 hp same rpm.
need different mag starter. came with square D 8536SCO3H30S. from what i have gathered it will not work with a 1 phase. It is electronic type with pass through for the wires going to motor and does not have "heaters". Thinking of getting Elimia brand but ....
calculated sheave sizes and it is turning pump at about 1000 rpm. Is this correct speed?
Also I'm concerned about an unload valve and check valve. The tube from high press. head looks like it does not have any check valve or unload valve. there is a Kunkle valve #348 on the low press. side before it goes into the intercooler prior to entering high press. head. Could this be an unloader?
Pressure switch uses 120V so I will have to run neutral wire to starter which is not a problem. Question is... can I just tap into one of the 240V legs and add a fuse to get my 120v for the pressure switch. do the starters come with different coils i.e. 120v or 240v? When ordering will I have to specify? Not real sure about all this..... Wish I could see a wiring diagram for the starter I will be getting.
Thanks to all. very informative forum I love lurking on internet forums the knowledge is amazing. Like a coffee shop discussion on whatever you want to talk about.
Ice
Ice
