OverkillYJ
I have a 3 cylinder 2stage T30 Ingersoll Rand 10HP Compressor. It was not building pressure past 70psi, but would not shut off when it hit 70 either, just kept running. I figured it was the 2nd stage valve, and rebuilt it yesterday. It was pretty much seized in place, but is now moving freely. The other low pressure cylinders I took a look at quickly, and saw the brass caps that depress the spring to open the valves were moving freely and looked extremely clean, so I skipped those and figured I would fired it up.
Now when its turned on the 2nd cylinder in stage 1 is sucking air in the intake for a few rpms, then randomly dumping air back out of the intake. Makes an interesting sound when that happens. The compressor is not burning up or getting too hot. The intercooler release valve between the 1st and 2nd stage is also starting to release pressure. My father in law plumbed the tank to the pressure control switch instead of the line coming off the heads like it was when we got it. I cannot remember what the line is that runs along the heads, but that is what was run to the pressure switch. So he plugged that when he plumbed the tank to the switch. If that line is plugged, the intake problem happens. If that line is open, then the Intercooller pressure release blows.
I have a feeling it is something simple like a valve sticking. I just dont want to go exploring before seeing if anyone here has seen this issue before. The gaskets kits for the heads arent cheap, so I do not want to tear apart anything I do not need to looking for problems. Also, this compressor is in a really bad spot to work on for an extended period of time, and is on a 220 gallon tank. After helping him out for hours yesterday, I am hoping I can get some fresh ideas here before I go take another shot at it. Thanks for the help
