Gerlacr
Just picked up an old Model 234 with a 1.5HP motor. Powered it up and the motor had a tough time coming up to speed so I pulled the belt off to check a few things out. The drag on the pump is way more than I expected. It is very stiff. I noticed the motor was turning in the opposite direction which would make the fan blow away from the pump. Not good. I pulled both heads off and the valves are grungy but not bad. The cylinder walls are smooth and oiled. There is plenty of fresh oil in the case. Any suggestions or theories about why it could be so tight? Did running backwards screw something up? Should I pull off the non-pulley side panel to investigate?
RonG
RonG
