rogersmithiii
- Joined
- Jan 15, 2012
- Messages
- 212
Curious if an Ingersoll Rand Air chisel is something useful? They don't seem to be real expensive. Curious what people do with them.
This. Beats swinging a hammer and much easier in tight spaces. Worth the $30 for any DIY or Pro.Is that like an air hammer? If so, then yes, especially if you live/work in the rust belt.
Cheap ones are worthless and irritating. Good ones are worth their weight in gold.
The hard hitting ones are great if that's what you need, but for stuff like trailer door rivets or side wall buck rivets they hit too hard and do more damage then repair.So, for the holidays "Happy New Year" I had a need for a better air hammer. After reading about all the famous brands and what they are capable of doing, I had intended of purchasing one of Astros models. However, my requirements are not as stringent or demanding as his. Also my financial situation at this time is boarding near the poverty arena.. So I hobble into my local "Harbor Freight" and walked out with there Chief air hammer model, CH401LB long barrel. I will tell you this. If you do not have a good grip when you squeeze the trigger, you will wish that you did. Anyway for my intended purposes this should do the trick. One note, this is heavy and makes plenty of noise. Hopefully it will serve me well in the near future
If its something you are going to use a lot, sure. Just keep in mind that while the tool itself might be cheap, the air compressor that you will need to run it properly isnt going to be cheap.Curious if an Ingersoll Rand Air chisel is something useful? They don't seem to be real expensive. Curious what people do with them.
Not really a lot of buck rivet tool bits do not fit/work well in the quick lock type retainer.I've had a few of the cheaper ones and they don't last very long, the casing splits or cracks or repeated use breaks the retaining mechanism , mine were always used to break the heads of rivets or cut rusty platework without resorting to a grinder. If the end of the chisel has a wire hoop to hold the attachment it's probably DIY level.
Some one at work has a blue point branded air hammer , with a sliding quick release chuck,that is powerful and hasn't broke, seen it drive bushes out and cut through corroded bolts, but it doesn't get used that much, the noise level is insane !
The bit you put in the tool is the only difference.So just out of curiosity what is the difference between an air chisel and an air hammer other than the bits? I have an Ingersoll Rand 114 GQC air hammer as a point of reference.
