I started on my Wolverine flooring project this weekend by hand grinding my 400 sq ft garage.
After about 15 hrs or so spread over 3 days, I am 75% done
After reading the DIY instructions provided by Wolverine, it appears hand grinding may not be sufficient to rough up the concrete.
I am hand grinding with a Bosch 1773AK with DC510 diamond cup wheel. It does a great job removing the sealer on the concrete, but I cannot honestly say that the surface it creates is rough to the touch. i want to avoid using muriatic acid.
I am thinking about renting a gas-powered pressure washer to clean out the garage after grinding. Will the pressure washer make the concrete a little rougher than it is now?
for those who have prepped with hand grinding, have you done any additional prep work prior to laying down the epoxy?
thank you
thank you
