Is It A Crime
FD611V
Did I read in another thread some days ago that it was a crime to own a section/piece of railroad railing? If so, well I'm guilty. I have two pieces that my father-in-law made for me way back in late 1960's when he worked for the old Frisco Railroad Co. In fact he also made two "dog irons" for the fireplace from the steel railings. Best darn dog irons for a fireplace and will last forever....I'm still using them this winter.
The two RR railing are different lengths, and one was cut by a torch, the other was by a saw as you can see. I don't know why my father-in-law cut a hole in the larger railing... maybe he thought I was needing it for a boat anchor, etc.
Also I have a old Littlestown #140 swivel bench vise that needs the swivel bottom. I've had this vise from the 60's and when the bolt that holds the swivel base broke, I set the base aside and that's when it disapearred..never to be found. If anyone here know where I could get a swivel base, sure would appreciate it.
Here are some pictures on the RR railing pieces that I use for anvils.
MD11
USA
I really like that idea for a small anvil... wonder where I can get a "legal" piece of railroad track?
ActAppalled
Lancaster, PA
Like the others said, it's not a crime. We go through about a hundred feet a month at work. One of these days I'm going to get around to making an anvil.
F
FD611V
Looks like a piece of art to me. Wonder how many files he wore out getting the shape like the bow of a battleship. Something to be admired.
jcbarry
South Jersey
It is not a crime to posses the stuff, one place I worked at used the stuff for ballast in house boats. There is a surplus supply store by me that usually tons of track for sale.
G_P
Central CT
That is too pretty to use as a tool. I could not bring myself to hit that with a hammer!
MD11
USA
I'm on ebay now looking for some.... most of them look rough, and the only decent one is too small.
Man I wish I had a machine shop!
That was probably done mostly with something like a blue flame wrench, a 4" mini grinder, with some finish work with files, and/or wet/dry sandpaper. Talk about having the patience of Jove... :beer:
adcrawfo
Depending on the size you can get a 20' section from a steel supply place. A buy 30 and 40 pound rail all the time for track at work. I don't have my book in front of me but if someone gives me approx size of the rail I can tell you which size to ask for
Sent from my (rental) Milestone X using Tapatalk
As a hardwood floor guy, the only crime is that benchtop.... I'd use a piece of stairnose....
Good Idea, I've a bunch of flooring leavings and am planing to resurface my loading bench with it. Hmm I think I have an appropriate Router bit or molding head cutter...
91bronc300
The horn, definitely. But the face looks like it was shaped on a mill to me. You would have to be very, VERY good with an angle grinder and file to do that.
91bronc300
oxy-fuel cutting/heating torch. Commonly oxygen/acetylene, though mine is oxygen/propane.
metal1313
clinton NJ
roughed out with a cutting torch
i should be getting some track soon. got some family who works for nj transit running the maintence crews, and theres a place called tracks unlimited right around the corner from me
