Is it a gimmick tool
Macduf
Seattle
Didn't get any directions with it. I looked at a video online where they hammered on it. For $2 it was worth the risk, just never heard of it before.
Bigblue&Goldie
Definitely not a gimmick. Those have been sold by just about every automotive tool brand for decades.
G_P
Central CT
Not a gimmick at all. Those are great to have when you have a big stubborn screw that needs to come out. The hammering drives the bit hard into the screw so it does not cam out and hits like an impact gun at the same time.
FigureItOut
Bentonville AR
Very effective and been around a long time. I just got a Cobra one at a yard sale for $4 yesterday and am looking forward to trying it out.
BFBOB
Yup, it's for real. Been around for decades - it was the only tool that could remove the Phillips engine screws from my '68 Honda 350. I still have the impact driver, but got rid of the Honda in favor of a BMW waaaay back, after the second engine rebuild in less than 50k miles.
djb2
Redwood forests
These are pretty much required for older motorcycles, with soft aluminum screws that seize into place. The pressure keeps the driver from camming out while shock wave breaks the corrosion and reduces the friction.
thebeekeeper1
Illinois
Like new and you got all the bits. You did GOOD! You don't need them often, but when you do, nothing else will do. :)
BTW, a set of quality bits (4 of them) will run you $25. ;)
redmondjp
Redmond, WA
Yes, these impacts are great for getting door hinge screws off, and also screws on tailgate latches. But you can't skimp out on the bits - buy name-brand impact-rated ones only.
dogdog
great for brake rotor/disc screws especially on Hondass, those honda steel part love to rust together. It's not the same thing as putting a 1/4 or 3/8 drive #3 or #2 philips bit on an air impact gun.
uart
Australia
On a related note, I just found another old tool that I was wondering about.
It kinda looks something like a drill/driver bit, but it doesn't seem to fit into any drill/drivers I own. I found a whole set of them, but there weren't any instructions. So are these things for real, or is this also some kind of weird gimmick?
Sorry I couldn't resist. :evil:
FigureItOut
Bentonville AR
You have to get a drill with a 1.5" chuck for that.
countryroad82
Kentucky
Like others have said, if you've worked on vintage motorcycles this is a tool that is an absolute must have. Spent more time I care to think of beating the mortal **** out of those critters....... It's especially fun when you miss a swing and get to play 'Did I Just Break Something Expensive Or Did I Smash My Hand?'
Boilerhouse
Muskoka
I have a 30 y.o. Craftsman that I use once in a while. It rarely lets me down. Mucked up a couple of the bits though.
NUTTSGT
Northern Central Ohio
I know a few guys that have them and rarely use them, but when they use them, they're glad they have them.
For $2, you definitely didn't get hurt.
cliftonbros89
Missouri
Have a couple of them. Not something I use all the time. However, they're nice. Used them several time on antique tractors.
slow
near Orlando
Honda Brake rotors as well, good tool, I paid around $40 for mine, but it was still cheaper than the dealer to do the brake service.
valentine
Geez , I can't tell you how many times that tool has saved me removing brake rotors from a Honda. Nothing else gets the frozen screws out as well.
-Valentine
My Old Tools
Hamrick Lake, TX
I was going to say they were standard issue for Honda screws.
CobraRed
This.
They work well the few times you need them. Nice to have around.
george4
N California
That is why I got mine about 30 years ago.
gungatim
west mich
I've had several over the years, first one I got when I was 12 because I didn't have air yet...btw, some guys don't realize the adapter for the bits comes off, and you can use it with a 3/8" drive socket...can't tell you how many guys I've shown that to who never knew...
uart
Australia
I've had one for over 30 years. Like others above, I only use it occasionally but it's a very handy tool to have. It's basically the original impact wrench/driver, predating all the powered ones we use today.
BTW MacDuf. To use it you first set the direction, typically by pressing the head inward and rotating it either left or right until it clicks into place. To test it just place the head (without a bit inserted) up against the edge of a workbench or similar and push hard on the body to force it in. You should notice that as you push it inwards the head rotates slightly (probably only 1/8th turn or less) as you go. Once you've tested it and verified it's turning the correct direction, to use it on a fastener you push it on firmly smack it several times with a hammer. Very effective at loosening seized up screws.
GTO
NJ,FL
+1
Very helpful,I've been using mine for 40 years
Farmall 1066
Suburban Rockford, NE
I have the exact same no-name one as the OP. Wailed hell out of it over the years, and got me out of a few jams.
Had no real need, but upgraded to a Snap-On a few years ago when one came up on auction cheap.
A little valve lapping compound on the screw head, and it's coming loose or breaking off!
JonDick13926
Sidney, Ohio
No. I bought one from Proto (probably one of the best values on one of these) and use it at least weekly. The more Hondas that come in for brakes, the more often it gets used. Definitely worth it.
L.Cheapo
I have an older Craftsman one. It works OK. I've used the SnapOn one...and it just feels much heavier, more solid, and like it twists more. Next time they're on promo...
CJM8515
Make sure if you are working on any japanese/import stuff you buy JIS bits. THEY ARE NOT PHILLIPS!!
sha
Texas
I got my first impact hammer set in a tool pile from a garage sale. I thought the same thing: gimmick tool? I didn't exactly grow up using one.
jmarkwolf
Southeast Michigan
Still have mine from when I was a dirt bike mechanic in the early/mid 70's.
Probably haven't used it since, tho.
Bought it new, but don't remember what I paid.
chris_1001
I've had one for 25 years, maybe more. Just did a brake job and never thought to use it on the retention screws. Stripped one out trying to get it out. Wish I read this or thought of that!!! Next time!!!
Prob use it once in all the time I had mine. Thanks for the tips!
unslow1
Illinois
If you are going to work on a motorcycle grab that and a 10mm. You will need both repeatedly.
