FunkyfullWidth
Been adding up what I need for wire and breakers in my garage. What I've figured so far is this.
I will have:
Lift 220v 15-18 amps 30 amp breaker, 10 gauge
Lights probably around 12 or so 4 bulb 8' lithonia's. so I estimated .85 x 12= 10.2 amps.
15 amp breaker 12 gauge
And then 12 gauge For a run to either of the garage door openers with an outlet at each. 20 amp breaker.
This would take care of all the ceiling runs for me. But it gets confusing because I'm not sure how to actually run things. I know what it is I want to accomplish, which is 5 rows of lighting on 2 seperate switches, yet on the same circuit. Would that mean I still have to run 6 seperate wires? 3 to each bank?
Also would I have to run seperate conduit for the lift, lights, and whatever else. I wanted to plan ahead and run wires and conduit for a heater because that is in the plans. I thought there were rules against how many circuits you can have in a conduit. If that's the case, could i have a few conduit runs, but go into one gang box and break off of that? I just don't want the conduit runs looking like a pile of snakes or a pipe factory.
so my plan is to just get 3 rolls of 12 gauge wire to cover the lights, outlets and garage doors. Should I do black red green? Then I was going to get 3 smaller rolls of 10 gauge for the lift.... How does this sound?
I will have:
