Is there a great cfm 60 gallon compressor ?
zkling
A great? Yes, a few but they are probably more than what you want to spend, and not of the proper tank configuration.
Otherwise just look for a real 5hp unit, most of those will be in the 15+cfm range.
P
PoorOwner
CA
If I am open to 80 gallon as well, what's the difference between 2 compressor that has similar cfm but one use 2 stage to get it?
CompressorPros.com
SC
There are a few small two stage 60 gallon units that produce 15 CFM. BelAire and Chicago Pneumatic have the same unit, just different color and decals.
BelAire 216V
Chicago Pneumatic RCP-561VNS
Definitely two of the bigger sellers for us. They both have a 2 year warranty that covers the whole machine, even the valves in the pump, which most manufacturers do not do after the first year.
If interested, here are the links...
http://www.compressorpros.com/air-compressor/two-stage/60-gallon/belaire-216v/
http://www.compressorpros.com/cp/ai...allon/two-stage/chicago-pneumatic-rcp-561vns/
Depending on where you live, we can probably give you a discount...just e-mail [email protected]
Loscaldazar
2 stage compressors essentially mean that the air is compressed twice. It goes in one cylinder, is compressed, goes to the next, and is compressed even more. Thus you achieve higher PSI in the tank.
And, a 60 gallon tank at 175 PSI will run tools longer than a 60 gallon tank at 125 PSI.
jptbay
I've got this one from Eagle compressors. LINK
18.5 CFM @ 100 Psi, 3 cylinder. Quality components - mine has US made motor and German cut-off switch.
Had it for over 10 years now and its been great. Very quiet compared to similar 60 gallon compressors I've been around. My buddy has this exact compressor from Snap-On. It is a re-branded Eagle that is painted red with a Snap-On sticker on it. Came with the identical Eagle owners manual zip tied to the side of it that mine did.
P
PoorOwner
CA
BelAire 216V
What's the difference between these 2?
Looks like just different paint on them
CompressorPros.com
SC
PoorOwner...you are correct. They are exactly the same. They come from the same facility in SC and simply a dual branding. BelAire is really big in the automotive market and Chicago Pneumatic has more recognition from people familiar with their Tools.
If you want more info on either or are looking for a deal, let me know
Ign
Butte Peak ND
BelAire 216V
He answered that in his first sentence.
