Is This A Good Deal (Drill Press)?
dthor68
Greer, South Carolina
I need a drill press and have been considering the 10" Wen for $125.00. Yes I am poor. I just ran across an add in Craigs List for a Buffalo FDM-16SP(GP) for $75.00. It says needs work but runs good. Looks like there is some medium to light rust.
The tag says it is 5/8, MT. #2, 1990, 3/4 hp, made in Taiwan. It is a floor standing unit.
Is this a good deal or should I stick with the Wen?
Thanks,
exmaxima1
Midwest
Most of the Taiwanese DP's from that era are pretty good, especially if it has the following features:
--Middle pulley for slow speeds
--Crank operated table
--Built-in light
I used a similar press like that many years ago and it ran very smooth. Definitely consider it if the bearings are good and the rust is not too bad. If it looks somewhat like my pic it should be a good DP (but clearly avoid bent/overloaded lift rack, and use a smaller bulb that fits into the head properly).
Davefr
OR
--Built-in light
^^^Agree. It'll be much better then a 10" Wen assuming the "needs work" is cosmetic or minor repair.
lilredex
Toronto
dogdog
anyone know where you can find that middle pulley ? is it universal?
Rewind97
Mississippi
$75 seems like a good deal. I’ve been looking for a standing unit and haven’t seen any under $150, while most are over $200.
I'd say good deal too. I've been wanting a floor model too and can't find a used one to save my life!!!
Davefr
OR
In my experience a lot of parts for these Taiwan DP machines are common. Try a similar JET at ereplacementparts.com
