I must be missing something here. I’m trying to figure out best way to insulate a 32X32X12 pole barn I just purchased.
I am reading all the posts on this site and must be missing or calculating wrong.
Most posts say lay 1 1/2 inch foam in between the girts. Seal the edges with can foam then frame out and put in fiberglass batts bringing it pretty much flush with the 6X6 posts.
I can skip the air barrier as I laid foam. I can skip the vapor barrier as I used backed batts. Then cover all that with whatever I want to finish the interior off with.
Adding up material for just ONE WALL equals $125 for foam. Whatever it costs for can foam to fill gaps. Then adding the fiberglass batts at $1,000 and I didn’t even figure cost of wood for framing and nails and screws.
So... for one wall it is 1,125 just for foam and fiber. Not to mention all I didn’t figure out as so far it is higher than a company coming in and spraying foam.
I was quoted for 4 walls 32x32x12 $3,200. The ceiling with 12 inches of blown at $1,200. So for $4,400 I could have all four walls sprayed and the ceiling blown.
Am I calculating wrong here with just one wall here at $1,125 without even figuring can foam, screws and nails and all the lumber to frame it out?
Thanks for the help.
