Is this single or 3 phase?
bigcreek
Idaho
By looking at this plate can anybody tell if it is 3 phase or single phase? It doesn't come right out and say it that I can see but didn't know if there is some kind of code word for it or something? :dunno:
bigcreek
Idaho
Ill have to check it out. Its at an auction and was just looking at it online. Its a metal cutting saw.
mm08822
It is as dr. Joe indicates. Get the cut sheet from emod if you still have time before auction. Send them pic of nameplate. Go to emod-motoren.de and fill in the contact info.
mm08822
The "S" might be referring to the duty rating of the motor. Another Euro motor I have has a "Duty" field on the nameplate and it is marked "S1". This is in addition to also having a "SF" field" of 1.15.
Its 3phase. The triangle/double star behind the 220V means that this is a Dahlandermotor... I just have the german wikipedia-page for it, sry.
https://de.wikipedia.org/wiki/Dahlandermotor
Yup, the 220 Delta/ YY on the data plate indicate such.
Is that a Scotchman cold saw?
Interesting. I couldnt see those symbols on the first few looks at it.
Why no HP rating?
Another issue, since this is a european motor, is the voltage and frequency! Nominal US voltage is 240v 60hz not 220v 60hz...
Dr.Joe
Germany
The HP rating is not commonly used in europe for motors.
It's the same with tools: the US seems to indicate the current draw even for marketing purposes. In Germany we use the power rating
