Island Workbench
Mighunter
Rhode Island
I'm looking for ideas on building an island workbench, maybe using harbor freight cabinets. I don't want a small space, looking for something fairly large by using several cabinets. I see a ton of workbenchs up against a wall but very few island types. Anyone have pics they can share?
Yankeefarmer
Connecticut
Two 36” wide cheap particle board kitchen base cabinets screwed together and sitting on a 2x3x1/8 rectangular steel tubing frame to carry the caster wheels. Top is a solid oak slab door my grandfather used in his basement workshop. Piece of 1/2” plywood painted red ties the back of the cabinets together and carries frequently used tools On stainless trim screw ”pegs.” Earlier iteration used pegboard, but the pegs dislodged too easily. This setup works perfectly for me.IMG_0631.jpeg
OccupantRJ
Eastern North Carolina
Wall work benches are flat surface diseases waiting to happen in my opinion. Being against a wall just allows items to be piled higher against the wall before sliding off the front. I will trade the extra square footage required to be able to work on all sides of something in progress.921F16C5-FA04-4D9A-B064-AD96BC8D7A86.jpeg
NUTTSGT
Northern Central Ohio
I have a work table built from old kitchen base cabinets. I then used 2x6s as frame to build the top with 3/4" plywood.
I also have a first generation US General 44" box in my enclosed trailer. It's bolted down to a steel frame which is bolted to the trailer. It has an aluminum sheet top that matches up to the other trailer cabinets.
You can may almost anything you can dream up. Extra credit if you can weld a steel frame together.
andyvh1959
Green Bay WI
Good ideas. Easy to find sturdy, older, heavier construction office cabinets at Restore or on FBM that could be mounted on a steel frame with caster wheels, and then a solid core commercial grade door laid on top, then covered with sheet steel.
Good point about having a large work surface cart/island versus a wall mounted bench, as I am one that likes to stack **** on a bench until its nothing but a buried storage surface. Gotta change my ways.
LXCam
I made one out of an old snap on. It the only wood top I’ve got in my shop and it’s always in constant use. This is the only pic I’ve got but you get the idea.
My Old Tools
Hamrick Lake, TX
In my shop it's called a table saw....
Mighunter
Rhode Island
Funny I find i do the same thing and I want to be able to walk around what I'm working on
Jackfre
N CA
These are a couple pics of a bench I made. I agree that a walk around is better, for me. Downsizing I have cut this frame down a couple feet in length. Top is two pieces of 3/4 pw 36x84. One mistake I made on this was having the top stretchers 4” below the top. Nice to lay clamps across but difficult to add some benches. I wanted something to sit without shifting. The feet a hdpe. I can throw a nylon sling around a leg to two and drag this around with some effort. On my floors it sits securely. I did not want casters on it, but limited mobility. In retrospect I would build two 36x48. If your floors are level that would be the hot set-up, imo.
66Caprice
Stanwood, Washington
Jack is a member here but rarely post's anymore. But his garage is an inspiration to all. Take a few minutes and watch his video for some great ideas. He has it posted in the garage gallery here on the site as well.
Renegade1LI
long island ny
I prefer island type bench and have a few. I like tool storage one side and open to load work on the other. Next bench i am building is starting with a 5 x 10 x 1/2" steel plate.
There are literally HUNDREDS of different workbench designs/build on YouTube. You need to decide it it is primarily for wood working or metal fab. Locking wheels are a good idea ! (Lots to choose from at HF.)
If you are doing woodworking, consider an area that you can place a "job site" table saw so that the saw table is level with the rest of the work surface. Removeable "wings"/extension on 3 sides are great for breaking down 4x8 sheets of plywood.
Dowel/pin holes in the top are useful. Personally, I would build it TALLER than average. Not that I am tall, I just don't like bending over when working on something. (Yes, big pain in the back to place heavy items on the top.)
RMERR
Northern CA
I have both against-the-wall and island type. Definitely handy being able to get to all sides of a project. For my "island" bench I used a lift table with casters so I can adjust height or move it if necessary. Radiused the corners and rounded over all the edges of a Shopmate top so no "jabbing" myself as I move around it.
Mighunter
Rhode Island
That looks super solid
Mighunter
Rhode Island
I tinker with old jeeps, don't really do any woodworking
andyvh1959
Green Bay WI
One of the pictures above show a pallet jack in the workshop. I've always thought a pallet jack in my motorcycle shop would be handy. But also, an island workbench would not need casters if you also have a pallet jack. Just use it when needed to move the work island.
walta
Dutzow Missouri
20250104_202928.jpgThe I The am going to beat it to death island has a 6-inch-thick cast iron top.
The Electronics Island top came that shape from craigs list and is about 7 feet long.
I can’t stand a work bench on wheels.
Everything in the shop moves with the pallet jack
Walta
OccupantRJ
On the equipment in my shop that has legs and is heavy or awkward to move I added a perimeter shelf type frame about 4 inches off the floor to be able to move those items around with my pallet jack. The bending brake in this picture is one example, and it provides a storage shelf for my Little Giant tap and die set to allow for the lid to swing open. The parts washer also has a lower perimeter frame. I have a forklift but it would not be useable in some areas of the shop. The pallet jack is parked protruding underneath a rolling work table to keep it somewhat out of the way.F2419B1D-39AD-4203-B2BF-F1FE26E52491.jpeg
OccupantRJ
If I had the Room I would have a table like this complete with Welding fumes exhaust system.
The table started off as a new piece of 1/2x4x8 plate in 1982 that I traded a heavy frame 5 hp 3 phase motor for. Plate was $208 back then, and a local fab shop needed the motor. The 3” pipe legs were free posts from the old large satellite dishes. Everything else involved in it was a good deal scrounged from a scrap metal yard or hunted down from Carolina Bargain Trader weekly sales magazine back then. I think I paid $20 for the pipe vise and about $40 each for the two Columbian vises. The all steel roll out table underneath was built by a friend who gave it to me when he became unable to use it. The exhaust hood is powered by an 8” gable mounted fan using metal duct with a butterfly damper right above the hood to prevent downdrafts. The hood has a fluorescent light inside it to help eliminate shadow areas on the table.
the table has served me very well for 32 years. This is a thread where I added some tool storage underneath.
Jgaz
I’m going to revive this thread as there are some really good ideas here.
My woodworking (and other) bench in the center of my relatively small work area.
I couldn’t imagine not having access to all sides of many projects I do
